Sony DCR-DVD101E DVD Camcorder Logo
A
Anonymous Posted on Aug 07, 2013
Disk is not accessible error- C:13:00
2000 impala problems
Well Can't fix this one with out a description Of Mentioned Problems,
Impala's can have approximately 13,00 different, Malfunctions
5helpful
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 • Motorcycles
D:\ is not accessible.incorrect function
plz 10067 diode is working fine okkk
1helpful
Disk error
That means that the lens are dirty, and the unit cannot read any disk.
Try first cleaning the lens using a lens cleaner kit (the ones with liquid cleaninc solution), like the one here :
Allsop Ultra Pro Lens Cleaner for CD, DVD and Game Consoles
Ifthat does not work, then you will need to access the lens inside theunit by opening the cover and accessing the lens pickup, and gently clean lens by using isopropylalcohol and ultra soft soft cotton sticks.
Here is how the lens look like:
Unable to access my disk with any operating system
Hey,
Seems you got a broken down drive, you can try it on another computer to see if the issue persits or take it to a computer repair shop to get it tested, no not wallmart, some real computer repair place
Thanks,
Ekse
Disk access issues
Clean dvd lens inside dvd compartment with fine n soft cotton swab carefully.
IO Device Error
My Maxtor died like this. The disk was OK, it was the electronics that blew. I bought a new empty disk drive box and fitted the disk drive and fixed it. Years later the disk still works in the replacement box and power supply. I got my files and data back with the disk drive in the new box. The size of that disk looks small today. It may be Parallel (PATA) and you need a PATA box, that is harder to find as obsolete. You need to try the disk first in another drive holder.
So PATA and SATA??? Look here and read up about it with pictures too:
https://askleo.com/whats_the_difference_between_sata_and_pata_and_ide/
An external disk unit has three main parts.
1. The disk drive.
2. The electronics box.
3. The power supply.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
