SOURCE: probs with camera and playing video on nokia 6288
Camera problem on this phone is a flex problem, change a flex and enjoy!!! 100% tested
SOURCE: in my nokia 3110 set camera is not working
Take the memory card out of the phone. Use the camera. Do you still see the same error.
If yes, Format your memory card and see if that works.
At last, if that would not work, Factory reset which can be found in settings menu.
Hope i helped you.
Thanks for using " Fixya " and Have a Wonderful day!!
SOURCE: N97 photo processing delay
Go to Nokia website and update/re-install your phone software to the latest version.
SOURCE: Hii, There is a problrm with
I have faced this kind of problem many times.But it is easy because the problem comes from the Memory Card.First remove memory card and restore your phone (Restore only). The only thing you have to do is to copy all the current files of memory to your Pc with a new folder.And format the Memory card. Before you paste the files check that the files are hidden.It should be hidden or affected by virus.After you have done all these paste the files and insert the memory card to your phone.If the problem still persist format the memory card and insert to your phone with empty data.Good luck
