Question about Dell Alienware X51 Desktop PC | Core i7 | 8GB & 1TB
Alienware x51 random restarts [solved: Dell had the audacity to supply the need with an underpowered PSU for the GPU they offered]
My x51 seems to suffer from random restarts. Sometimes before a random restarts happens the fans would go on overdrive and then 2 seconds later crashes and restarts. No BIOS error, restart as per normal. I then further realized that these restarts don't happen under intense gaming or some sort, but during youtubes and playing audio/video streams from the internet. This is all I managed to dig up. Anyone know what's causing this and solutions?
Posted by Wiryan Tirtarahardja on
  • florida Wilson
    florida Wilson Sep 13, 2018
    I am using Dell Alienware gaming laptop from last two year and recently I watched a movie and my laptop whether it is just sitting idle, if I'm watching a video, playing a game etc. It will just randomly restart. At first, the screen goes black and at the same time, it sounds like the fan goes crazy. then I went throughhttps://www.delltechsupportnumbers.com/d... and they helped me a lot to resolve my all issues.
Cato Pedersen
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
Hello Wiryan =)
Sounds like either a power supply or graphics card issue to me. You could try downloading Almico's speedfan to check your temperatures just to be sure that they are fine.
You should contact Dell, they can probably troubleshoot the issue pretty fast/send a technician to you. The X51 randomly shutting down is a common issue if you check the forums over there. http://en.community.dell.com/owners-club/alienware/f/3746/t/19437557.aspx?PageIndex=1
I assume you have updated every driver to the latest?
Hope this helps! :)
Posted on Aug 07, 2013
Testimonial: "So I ran some tests as well, A) its not an overheating issue, since the GPU is operating under the maximum ceiling temperature. B) drivers are up to date. C) tried changing the nvidia settings, made it worse so i sticked to defaults And i've been looking around forums and such and nobody seems to have a definite answer, now that overheating is ruled out I guess."
Larry Ng
  • Dell Master
  • 5,982 Answers
Florida Wilson
You nor the OP ever told that X51 you own,
X51,xxxxxxxxxxxxxxxxx what is the x numbers.
that PC power needs vary alot. ( seen vast posts all doing it wrong)
it's called a power budget if you take a class in electronics.
Power is a day1 learning event. do so.
huge variances POSSIBLE on topic POWER.
from 300w, to even as high as 1000watts.
(more if running Bitcoin BS systems.) i digress.
The PSU must run the mobo neat, (has spec)
then if not running SSD but running 3 HHD 3TB each it needs more power.
them that endless chain of GPU cards., (vast cards exist no 2 the same)
examples real, and expected all by me,,, before the changes.
my GTX1050 uses near no power, at all 75watts max, 60w par gaming , but way less power not gaming (a real good BUY)
60FPS on Farcry 5. (new)
but PSU must handle peak watts total, or it fails !!!!!!!!
my old 650 GTX burned huge power , and made huge heat)
(as its book warns you if you read it it says 30 amps on the 12vdc rail or it will FAIL !!!! )
360watts all by its self, it blasts hot air into my room. no room heater needed in my den. LOL
so 360 + 330 is what. 690watts just for 2 things. (800w psu buy it)
my gtx650 is now retired, and in an attic box,
learn to not lay blame on others, when you build a pc.
or update a PC, (that is under YOUR STEAM) ok?
many are clueless what power even is ? (P = V x I (amps)
The PSU must regulate power and not overload.
if you over load it the PC will crash, or turn its self off)
ERROR 2 is if your GPU card has the 8 pin AUX power cable. and is not connected the GPU will crash. (fail for sure)
my 1050 has no such jack, it uses tiny currents and screams fast.
buy a new GPU.
tell me what is in that box of yours, all parts (parts MATTER)
  • mobo name and model
  • GPU (cards, PCI-express) name and model. be exact here.
  • HDD and not all SSD. and how many if HDD? drives.?
  • what PSU.? watts, rated????? 300/500/800? less is crazy
and we can talk , now if these facts are conveyed to me.
easy,,. it's just POWER (volts times amps)
Then comes, (cooling)
if it is not a power issue, then update your GPU card drivers.
"no one, has and answer"
I hate to break the news to you but computers are not toasters.
and...
well gee you are in text box. with no facts posted. at all
zero inputs. just vague systems mentioned
"fans go overdrive", well gee it sees it overheat and tries hard to end it and can not. bit, the case has no case fans.????
no GPU stated, some have there own exhaust port to the rear.
(better this is)
but in all cases.....
others do not, all GPU needs cool source of air inside the case
if not the GPU/CPU will overheat. the cure for that is fans. in the case for sure the front, and the room you are is coo, not 120f rooms.
ok, we run 77f here all summer deep south..
no problem with even the hottest running GPU made, here.
but we have nice huge case fans.
next is this (we use a temperature probe inside the case to see truth, we see 80F max)
"its not an overheating issue, since the GPU is operating under the maximum ceiling temperature. " why not say what that is???????
Facts are 90c is max for most processors. 50 to 60c is normal
mine is 39C now as I type, (pro grade system hand made by me)
'never 90c even your CPU will self shut off at 90c for the same reasons.
GPU's crash for 3 top reasons
1: tiny PSU with no consideration for power budget.(or cables missing)
2: wrong software driver , or corrupted OS!
3: overeheating the GPU. learn to get a free app, and log those temps to file and read the file after it crashes, omg 90c:????
op never once stated full model. #
ONE :
Alienware 51 AX51-5725BK came with
NVIDIA GeForce GT 640 x16 HDMI (no brand stated it's not DELL)
if that is missing or changed , that is your problem. you change.= your job on your STEAM.
or this
Dell Alienware X51 R3 i5 6400 Quad 2.7GHz 16GB DDR4 3.24TB SSD GTX 970 4GB GDDR5
as you can see X51 don't mean squat !
if you upgrade ANY PC not just DELL or X51
upgrade the GPU card,
first ask how, my guess is you skipped asking a real tech, how first.
it's like saying I drive a chevy
and forgetting to say Corvette, and HO engine size.
see what is in the box is what matters, first.
good day and good look doing upgrades blind.
Posted on Sep 13, 2018
  • Anonymous Sep 13, 2018
    Florida Wilson hyjacks an laptop over,desktop x51, why do that.
    but i guess you laptops overheats
    so load and run the whats my PC temperatures
    app.
    run that. and learn to:
    1: CLEAN THE pc EVERY YEAR OF LINT
    2: and never it on a blanket (or any thing that blocks vents)
    ask or google for that app program.https://www.techpowerup.com/realtemp/
    or
    HW_monitor. ( I use this)
    http://www.tomsguide.com/forum/245467-49...
2 Related Answers
Anonymous
  • 1027 Answers
SOURCE: 8mb of video on my pc and youtube and any other
The display of video is not dependent on the video ram, but on the connection to the internet. Dialup just wont work, as the feed is too slow.
Posted on Sep 29, 2009
Anonymous
  • 285 Answers
SOURCE: Computer crashes and vista says it is NVIDA Geforce
If I were you I'd wait for the next driver update. ALso, you could try sending Nvidia a complaint about this, so they know they've got to fix it.
I hope this helps,
Yannick
Posted on May 29, 2009
Random restart
This definitely sounds like the CPU is overheating, graphics card is overheating, or your memory is failing.
Check your CPU temp. and fan, and check graphics card fan.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 13, 2010 | Biostar P4VTB Motherboard
Gateway 7426 GX shuts down randomly after fan revs for a few seconds. Sometimes it can run all day fine and then bam!, does seem to happen when I am actively working or have many programs running at once....
This seems to be a motherboard related issue. I am having the same problems. Some speculate that it is something to do with the cpu throttling causing the cpu to think it's going to overheat and so it shuts off. Others think it's a faulty cpu temp sensor. If you keep the laptop idle (no intense video applications), then it won't do it, but that makes it very useless. Also, make sure both fans work as the system has 2 inside. One seized and ruined one 7426 on me so I got another for cheap and now it's happening.
Jan 07, 2010 | Gateway 7405GX Notebook
Shifting problems
never seen a dodge and autos a bit thin on the ground here in spain but i think the control you are looking for is on the side of the gearbox ,and if its like VW then its not cheap ,i repaired one by removing the offending item and drilling the rivits out then cleaning with acetone the paths on one side and rubbing a soft lead pencil on the brushes refitting a couple of nuts and bolts with instant gasket in the join and this car is still driving around a year later.
Oct 23, 2008 | 1994 Dodge Intrepid
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
Powers on and off randomly
one of your tubes are bad...call tech
Nov 26, 2007 | Toshiba TP55H60 55" Rear Projection...
Dell Latitude D800 PC - Fan-2-CPU problem
There's a second fan beneath the keyboard, you need to pry open the top panel where the power buttons are, then remove 2 screws for the keyboard to come off. When I did this, I saw the second fan with dust blocking it. I used a vaccum cleaner and my D800 works perfect again. One reason why the top left corner fan runs at full speed is that it reacts to the other fan being disabled, kind of like an emergency detour for the heatsink.
Oct 27, 2007 | Dell Latitude D800 Notebook
Startup problem
This could be a corrupt bios or a low cmos battery, follow instructions. Take the right hand side panel off the pc. Look for a disc shaped 3V watch type battery and replace (Very cheap) Look on the motherboard and reset the bios at the 'JBAT1' terminal put jumper(little plastic cap) from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Restart pc and enter bios when prompted(or press F2 or DEL on startup) to set time and date, save settings and Exit bios. It should now boot ok.
Jan 25, 2007 | Systemax AOL Optimized PC (100607) PC...
Dell Alienware X51 Desktop PC | Core i7 | 8GB & 1TB Logo
1,367 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
