Philips 32PT5441/37 32" TV Logo
julia webber Posted on Apr 04, 2009
Philips 7 year old 32inch cuts off while a high pitched buzzing sound stays until the tv is switched off at the mains
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
155
Points
IF PICTURE PULLS ON RIGHT ADJUST BRIGHTNESS AND AND TINT UNTIL SCREEN SHOW FULLY AROUND PICTURE
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
I have an Element flat screen TV and it keeps making a high pitched clicking noise.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
1helpful
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
I keep getting a very high pitched noise / buzzing from my TV even when volume is muted! its spoiling the viewing. its not always there but its all to frequent now. TVis 3 years old
The power supply is a switching mode power supply. They work at high frequencies. Sometimes they produce harmonics that can be heard by people. The power supply may need to be replaced if it get really bad.
Rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
2answers
Buzzing noise
If the sound goes out completely, try hitting the mute button (to mute it) and then hit it again (to un-mute). I've found that this work-around typically gets it working, at least.
1helpful
4answers
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
