The menu does not have a choice to change from antena to cable how do I get it on cable
Typically, your cable box will have two inputs & one output that goes either thru your VCR for recording puposes or just direct to the TV. Your switching will happen thru your cable box, like an A/B switch, designed so that when cable is down, you can switch over to locally broadcasted TV stations. With DTV now in play in most areas, you will want to connect the antenna's connector to your DTV box, then connect it to your cable box for switching back and forth. The new flat panel TVs already have a digital receiver built-in, so in that case you would eliminate the DTV box.
