Question about Sony KP-57HW40 57" Rear Projection Television
SOURCE: Sony KP-57HW40
hi, I was reading forums on other sites and someone posted a solution- replace the hv splitter/focus/screen block. I have similar problem with my set and was wondering if you had yours fixed and how. I haven't tried replacing the above parts because still searching for the best solution. so please email me if you have your set fixed and how. thanks Arv
Posted on Feb 14, 2007
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal
deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have
failed. There are, for example, a few hundred parts and a section of
the Jungle IC chip involved. So, repairs could require something as
simple as replacing some inexpensive passive components OR as
complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
SOURCE: Blue Screen and TV shuts off
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Posted on Dec 31, 2008
SOURCE: Sony KP -57HW40 - Green Picture Tube - part new/used
CONTACT VIDEO DISPLAY AT 1-318-747-0140 AND TALK TO CHARLIE I GOT MY BLUE ONE FIX IN 6 DAYS!!! AMAZING FOR ONLY $152.00 THATS CHEAP YOU JUST HAVE TO SEND IN YOUR OLD ONE AND THEY REPAIR IT! AWESOME COMPANY!!!
Posted on Mar 30, 2009
SOURCE: The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
Posted on Oct 07, 2009
Jul 08, 2011 | Sony KP-57HW40 57" Rear Projection...
Jul 12, 2010 | Sony KP-57HW40 57" Rear Projection...
Feb 07, 2010 | Sony KP-57HW40 57" Rear Projection...
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
Nov 21, 2008 | Sony KP-57HW40 57" Rear Projection...
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Apr 20, 2008 | Sony KP-57HW40 57" Rear Projection...
Jan 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Nov 11, 2007 | Sony KP-57HW40 57" Rear Projection...
Nov 10, 2007 | Sony KP-57HW40 57" Rear Projection...
18 people viewed this question
