Question about MK Battery U-1 Sealed Gel Pair Power Wheelchair Battery
Can I recharge a 24v gel battery with the automotive battery charger?
Posted by acene99 on
Anonymous
  • 40 Answers
 yes. only if the volts have fallen below 24VDC. I would`nt make a habit of it though
Posted on Apr 05, 2009
How do I access the battery? And how do I recharge the battery?
Battery is Usually located under the seat of Most Motorcycles. Remove Battery and Get a 2amp trickle charger for both Wet and Gel Cell batteries Fallow Normal Charging inst.
Sep 23, 2015 | Motorcycles
Light on the charger is not on when plugged in n
If the red light on the charger is not on when plugged in then the internal fuse has blown. This can happen if the batteries have been drawn down too far for the charger. If the batteries are really discharged too far, then you'll have to use an automotive style charger to recharge the batteries individually. Do not use an automatic charger. The last time I did a recharge of a depleted battery using an external charger it took 3 days (72 hrs) of continuous charging to recover the batteries. If this doesn't work then the batteries will need to be replaced as well as the fuse inside the 24 volt charger.
Oct 19, 2014 | Health & Beauty
The charger that comes with Homelite 24v mower is crappy. I've gone thru 3 of them. What's a better alternative?
I have used a DieHard portable battery charger (model 200.71222) for several years to recharge my 24-volt, 18-year old Craftsman mulcher, model 315.370270. This is after the on-board charger died. I just disconnect the link between the two 12-volt batteries and remove all other battery connections. Then connect the charger leads to the positive and negative terminals on one of the batteries before plugging in the charger. I put the settings on the charger at conventional low maintenance and 2 amps. Charge one battery and then the other (assuming you have two 12-volt sealed lead acid batteries like my mower). I use binder clips 530-t.jpgfrom an office supply store to hold the battery wires on the terminals when I'm mowing...makes it simpler to remove and reattach for charging instead of the nut-and-bolt connectors that came with the mower.
May 14, 2012 | Garden
Coleman 18v drill CTP 8129 number 9408 label underside drill. Probably 30 hours total usage over 2 years. Appeared not to hold charge after 18 months - had to recharge before every use on a 1 week...
These batteries never last very long. That model of drill is no longer made but I did find some refurbished batteries on EBAY. However, with EBAY you get what you get. Personally, I would never buy a refurbished battery and besides, they are way overpriced for a refurb. Sorry my friend but you would be better off just buying a name brand drill with Ni-cAD batteries (18V or 24V are the most common). I have a 24V DeWalt that I love and replacement batteries are cheap.
Aug 01, 2017 | Coleman Drills
Controller has single flashing red light. how to correct fault ?
The batteries are low and need charging If after you charge and you still have the single red light then you need to replace the batteries
Dec 07, 2010 | Health & Beauty
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
Just purchased it used. Both battries show
If the horn won't work, the batteries are dead. If the charger is showing green lights, most likely the gel inside the batteries has gone solid from the chair being stored for a while. Replace both batteries with type U1, 24v, 33 amps and see if that will clear the problem. The fuses are regular automotive type fuses.
Mar 06, 2010 | NRS Hoveround MPV 5 - Used Power...
Battery goes flat frequently after 5 days not used. Ford say that it is because of electrical componentry runnign all the time and you have to expect this. Is this so? I have put in a new gel battery and...
Why are you using a gel battery?? you shuld only be using a starting battery. Gel batteries, when weather gets really cold, will die out and cannot be recharged. They are not like a typical starting battery made for the vehicles large drain when starting.
Dec 14, 2009 | 1998 Ford Explorer
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
MK Battery U-1 Sealed Gel Pair Power Wheelchair Battery Logo
278 people viewed this question
Top MK Battery Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a MK Battery Health and Beauty Expert? Answer questions, earn points and help others
