Question about RCA S1000 MP3 Player
RCA S1010A MP3 PLAYER. COMPUTER RECGONIZES IT BUT RCA EASY RIP WILL NOT.?? RUNNING WINDOWS XP HOME.
Posted by stacy916 on
  • pipirin Apr 09, 2009
    my RCA mp3 has songs in it and everything but when i disconnected from the computer and im going to listen to it, it like frezzes up and the song just won't play
Anonymous
I am having same problem if anyones found solution please let me know, [email protected]
Posted on Jun 07, 2009
My new RCA lyra mp3 player will not install easy rip to this computer
dont even bother with that software use windows media player, open windows media player and insert your cd and click on the rip tab rip the music to the library the sync it to your mp3 player enjoy you can even use it to sync the new music to your player
Sep 15, 2009 | RCA Lyra RD2765 MP3 Player
When i got my rca mp3 the easy rip software was able to open.
If you have upgrade your computer after it was busted, that could cause your old version of the easy rip software to not recognize your rca mp3. what you'll prob need to do is update the easy rip software.
Aug 17, 2009 | RCA M4208 MP3 Player
Rca easy rip
I would have to say that vista is the problem. Many people are happy with there vista, mainly becuse they only have programs that fit it. But i definitely think that microsoft could have done better. So i would have to say that because you have XP, you should use it. And if there is a button that says sync or connect, try it. I am happy that i could help:)
Jul 19, 2009 | RCA M4204 MP3 Player
Rca mp3 easy rip software will not load
If you are running windows vista or XP, try running the easyrip installer as an administrator. To do this, right click the installer program file, and choose "run as administrator" (third one from the top).
Hope that helps.
Jul 10, 2009 | RCA M4208 MP3 Player
MP3 Player not recognizing Real Player Video Files
That Opal's Easy Rip Software does not recognize Real Video format naturally. You may have to download a free program called Riva FLV Encoder to convert the Real Video files to AVI format. Once they are in AVI format, the Easy Rip software will recognize the file and convert them to your player. If you have lost your installation CD, you can get the Easy Rip software from:
www.rcaopal.com
-Tha Mp3 Doctor
Mar 12, 2009 | RCA OPAL M4001 MP3 Player
Easy Rip Software
Plug your RCA M4208GR-B MP3 player into your computer with the USB cord. After the computer recognizes it.
STEP 1 click start
STEP 2 click MY COMPUTER
STEP 3 Right click the associated drive letter (i.e. OPAL) to show the option menu.
STEP 4 click "install RCA easy rip"
Jan 25, 2009 | RCA M4208 MP3 Player
Easy rip keeps freezing up and theres no sound on recorded videos
Make sure you have the updated Easy Rip software from RCA's website and that the lock switch on the back of the player is not turned on.
RCA M4208
Make sure the lock switch on the back is in the unlocked position. For the player to say "Loading," especially the first time you plug it into the computer, is normal - your computer is communicating with the player, installing drivers, and trying to load the Easy Rip Software. If it stays on loading past 10 minutes, however, something is not right. If you have selected to open the device automatically using Windows Media Player, you are headed for trouble, especially if you have more music and other files on your computer than the mp3 player can handle. If you have accidentally done this, disable auto-sync in Windows Media Player.
If you have checked the above, and you are still having problems, disconnect the mp3 player from the computer. Hold in the power button for 10 seconds or more to reset the mp3 player. Try plugging the mp3 player into the computer again. If it stays on loading for more than 10 minutes, unplug the mp3 player, go into the settings menu and change the mode from MSC to MTP or vice versa. If it still misbehaves when you replug the mp3 player into the computer, download the latest Easy Rip software from RCA's website and update your player's firmware - take note of the section they have on Windows Vista if you have Windows Vista. Good luck!
-Tha Mp3 Doctor
Jan 02, 2009 | RCA M4208 MP3 Player
Can't get installed
Windows XP Pro is very nasty when it comes to reading mp3 players. The OS is designed for maximum secuirty, so unless you change the security settings, it treats the mp3 player as an "unauthorized user". Here is some general TS to try first:
RCA M4208
-Tha Mp3 Doctor
Dec 26, 2008 | RCA M4208 MP3 Player
RCA M4208RD-B MP3 Easy Rip software issues
Turn your player on and go to settings. Scroll down the menu until you see "PROTOCOL" and switch it from MSC to MTP. Your computer will now recognize your device, and you will be able to add whatever you want to it.
RCA S1010A MP3 player
connect the player to the pc1.gif,
open my computer1.gif, look for the disk icon for the player.
right click that icon, scroll down to format.
Jan 14, 2008 | RCA S1000 MP3 Player
RCA S1000 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Jean Sintulaire
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
