Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have 2 kicker l7's 4ohm, how do i wire them down to 2ohm?
Posted by jlw2323 on
Tygh Duval
    Sergeant:
  • 300 Answers
If the subs are dual 2 ohm voice coils.....
  1. For a each sub, connect one of the "+" terminals on the sub to one of the "-" terminals. This makes each sub 4 ohms.
  2. Connect the unused "+" terminals of each sub together. Do the same with the unused "-" sub terminals. This makes the sub combination 2 ohms.
  3. Then connect the "+" and "-" sub terminals from the above step to the amp.
If the subs are dual 4 ohm voice coils, you can't connect both subs in any fashion to get a 2 ohm impedance. The best you can do is make a single sub 2 ohms by connecting both "+" terminals together and both "-" terminals together or the pair of subs 4 ohms by doing the same, then connecting one sub's "+" terminals to the other sub's "-" terminals, then connecting the other "+" and "-" terminals to the amp.
Posted on Apr 04, 2009
I have a comp s 12 2ohm kicker and a comp vr 12 dual 2ohm kicker how do i wire these to stay at 2ohms to the amp
you can wire them to be at 2ohm load you need two of the same speaker. its is very bad on the amp to run like that and you will not get a good bass sound because one will over power the other sound wise
Mar 23, 2013 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
I have 2 18" kicker
First you need the OHM rating of the subs. Most of the time its on the box or the magnet on the back of the subs (normaly 2ohm 4ohm or 8ohm) And that of the amp. Most amps are 4 ohm output if its a 2channel and 2ohm output if its a mono. You NEED to know these cuz wiring it wrong can blow channels in your amp or cause it to cut "in and out"
Jan 17, 2011 | Kicker Car Audio & Video
I got 2 pcs of kicker 12L7, one is 2ohm and the other is 4ohm DVC. in there any chance i can run them together with one amplifier? i got a venom VD2600S and venom 1600.D, will it be ok if i use each...
Run the amp in stero Run the 2ohm to one chanel, Wire the dvc 4ohm to run 2ohm + to + - to - to the other chanel and you should be fine.
If you had a 1ohm stable amp you could run both speakers wired 2ohm to a mono amp and have a 1ohm set up and double the power!
Feb 04, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do you wire four 12 inch kicker cvr dual voice coil, to a 2400 watt 1 channel class d amp
Hello brysonford00,
The wiring configuration depends on what final impedance you want the amp to see. If the subs are 4ohm DVC's, you can wire them to present a 2ohm impedance or an 8ohm impedance. The diagrams are here. If your subs are 2ohm DVC's, the wiring is the same. The impedances will be 1ohm and 4ohms.
Hope this helps.
Jun 07, 2009 | Kicker CVR12 Car Subwoofer
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
I have 2 kicker l7 12 dual voice coil subs.. i just friend a hifonics 1600w amp and am wondering if a kx 1200.1 kicker amp will be enough to power them they are 750w rms a piece .. can these be run at 1...
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
Apr 23, 2009 | Kicker KX1200.1 Car Audio Amplifier
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Oct 25, 2008 | Kicker Car Audio & Video
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Apr 08, 2007 | Kicker (ZX750.1) Car Audio Amplifier
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
593 people viewed this question
Top Kicker Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Charles Tidwell
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
