Question about Whirlpool Whirpool 26 cu. ft. French Door Refrigerator w/ MicroEdge Shelves -
I don know how to turn on the ice maker of a french four door refrigerator
Posted by vilma rivera on
MARIO GUTIERREZ JR
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
Water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Posted on Aug 07, 2013
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Posted on Apr 27, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Whirlpool Model GS6NBEXRL01 ice maker not making ice
Most likely the water control valve on back of the refrigerator near floor or the thermostat inside the ice maker is defective. You can fill the ice maker with water from tap and see if it cycles one time or you can check the control valve solenoid that feeds water to the ice maker. Click on link below and then paste your model number in model search feature. That takes you to a page with breakdown photos of the parts I mentioned. On the left of your screen click on photo # 12. If you need help with this I am here, just let me know, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
Anonymous
SOURCE: Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
Posted on Jun 05, 2010
Anonymous
  • 1099 Answers
SOURCE: water does not dispense thru my whirlpool
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
Follow these steps and this will solve your problem.
Hope this helpout......
Posted on Aug 04, 2010
Installing frigidaire ice maker
Hello friend, thanks for your post!
Depending on which style Frigidaire refrigerator you have it is different priming each water line. For a top mount refrigerator you would need to install the icemaker and turn it on with the wire arm. The first cubes of ice for 24 hours should be discarded. On a side by side refrigerator and a french door bottom mount you would need to push on the water dispenser for two to four minutes releasing the water into a glass. I hope this information is helpful.
Aug 30, 2014 | Frigidaire Refrigerators
Samsung french door fridge has clicking ice maker, what is wrong
The gear that turns the ice maker is Nylon and is most likely striped
You would be better off replaceing it with a New One, find it on ebay
Apr 28, 2014 | Samsung RF265AA Bottom Freezer French Door...
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Samsung RF266AEPN
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
LG french door refrigerator ice maker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 11, 2010 | LG LFC25770ST (250 cu ft) Bottom Freezer...
Ice maker doesn't work
Unplug Ice maker from plug on inside wall, remove and let thaw. Don't worry when removed the water will not enter the freezer. Let me know if this works as I get very little support from LG. Thanks, Se Breeze
Jul 30, 2009 | LG LRFD25850 French Door Refrigerator
Ice maker doesn't make enough ice
Try turning the thermostat all the way down if it works you can back it down.
Nov 21, 2008 | GE Profile PFS22 33" Artica French Door...
Whirlpool Whirpool 26 cu. ft. French Door Refrigerator w/ MicroEdge Shelves - Logo
133 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
