Televison & Video Logo
Posted on Apr 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Att uverse remote won't work with other devices
Just bought a new samsung ln40a50 40'' lcd dvd and a samsung blue ray dvd player. my standard att u-verse remote won't work on either device. i've tried all the codes supplied by samsung and also the master programming code supplied by att...nothing works. any suggestions?
Lani Tuggle
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 73 Answers
  • Posted on Nov 11, 2009
Lani Tuggle
Expert
Level 2:
Mentor:
Answers
73
Questions
0
Helped
57723
Points
211
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
I need the AT&T UVerse remote code for my samsung blue-ray player BD-D5700
Access the help section of the menu on your uverse connected TV. Select the option "Remote Control Setup". Select your style of remote and select the type of device that you want to program your remote to and then just simply follow the instructions provided on-screen.
Feb 01, 2014 • AT&T UVerse
Att Uverse remote set up code for Sony Dvd player
Google for it by model numbers but I doubt you will find one that works.
Need remote code samsung hd860
For the ATT Uverse Remote the code is 2340.
What is the att uverse remote code for Protron PD-DVR100 DVD Recorder
hi,
Do you mean AT&T U-verse remote. then the code for protorn dvd plyaer is 2149
ok
2helpful
2answers
I have Att Uverse and a Samsung LCD. We have
If your using the IR remote, the actual colors of the tv are what is causing your problem. What I have found to solve this is go to your local ATT corp. store and order the RF remote this will solve your problem. The techs don't carry these on their truck.
Codes needed for Samsung TV, Samsung Blue-ray & ATT Uverse
hi! i have a couple of codes here for your samsung tv. just try them 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 hope it would help! goodluck!
16helpful
4answers
Att uverse remote not working with Phillips lcd?
I just did some research on this problem and found a fix. If your tv has a powersaver feature on it turn it off i put mine on standard and my remote works fine now. weird but it works!
Cant get rid of black baras on top and below while watching DVD's
The TV remote may have a button stating Aspect Ratio, or similar. Usually when you keep hitting it, it may cycle through available settings like 16:9, 4:3, Wide, Zoom, etc. If not, or if the remote doesn't have this button, check the TV's onscreen display but usually the source device like the DVD player is in control of how the image fits the screen so the DVD player's onscreen display or it's remote may also have the Aspect option so check it as well. Todays TV's are alot like PC monitors and they "talk" to the device in control of the signal. Your Samsung may have worked better with the Blu Ray, or maybe it's the other way around but your new LG may not have an automatic adjustment like the Samsung may have had.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
