Question about Technics SL-1210 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
How can I slow down the internal speed of a technics 1200 turntable? they are both in excellent condition however a servicer set them to a point where at ''0'' they are as fast as +1.5-2. They play faster than needed. What can I readjust to get them back to a normal speed?
GrandMaster KC
Posted by grandmasterk on
  • 1 more comment
  • grandmasterk Apr 05, 2009
    not the pitch control at a true zero, what happened was it was serviced and the tech did something on the adjustment that speeds of the turntable. 0 is lik +2, +2 is as fast as +4, I need to know what internal adjustment I must make to slow it down, like the brake adjustment screw.
    The turntable go's to fast need to adjust internaly to slow the speed of the TT. warranty has expired just need to know what adjustment internaly increases and decreases the speed of the deck?
    found it myself. it is a pitch adjust screw under the plate cover turned down and problem solved.
David Dunn
    Brigadier General:
  • 8,546 Answers
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Posted on Apr 04, 2009
  • 1 more comment
  • David Dunn
    David Dunn Apr 05, 2009
    If a non-zero zero reading on the slider is unacceptable you might just take it back to the guy who modified it. Is it not possible to just use the strobe on the platter to find true zero?
  • David Dunn
    If we can't help you with an internal adjustment - is it not possible, using the unit's theoretical -8% speed capacity, to find true zero until an answer can be found? Or is the speed control broken?
  • David Dunn
    Great. Good job. Thanks for the feedback.
When I connect the vsg1200 v2 the download speed is good (speakeasy speed test) also the upload speed is good. When you access the internet all of the web pages are painfully slow to load. If the...
Hi, I experience also performance issues with the VSG 1200. Did you found a solution in the meantime? I already have the latest firmware installed. I notice that within the internal LAN ping times are sometimes too high to the device
Oct 07, 2010 | Zyxel VSG-1200 V2 Router
I have just bought a pre-owned Technics SL BD-22 turntable and the speed is variable - when I adjust the pitch adjustment wheel it seems to get worse. On listening to familiar music it seems to be running...
Have a look at the bottom of the turntable. This type of turntable often have speed adjusters. They might be covered by a sticky label or something. If you can't see that go inside by removing the bottom and look inside for them. There should be two, one for each speed.
Sep 21, 2010 | Technics SL-BD22 Turntable
When i turn on my technic 1200 turntable it the lights flicker and looses audio sometimes
Hi, i doubt the 2 are related as the T 1200 doesnt have a preamp, only speed control.
Maybe try checking to if there are any loose ground wires in the turntable (ONLY if you are comfortable to open)
Other than that it the sound issue might be either on the head, or on the phono outs not connecting properly.
If the speed is remaining good, then the issue is just with the LEDS themselves, maybe loose solder, if it is changng pitch as well, then dry joints in the power supply/pitch control
Hope that helps
Jul 15, 2009 | Technics SL-1200 Turntable
I have a 1200 technic turntable mk2
some times static charge fomr your hands or other things make this happen...don't touch the pole in the middle while speeding it up or slowing it down...if you mixing tracks...either shove the record or touch the edge of the platter...touching the pole send statis from your hands down the pole to the motor and it just takes off...I have been djing for ten years and in the begining it happend to me...
Mar 25, 2008 | Technics SL-1200MK2 Turntable
Braking not working right
Well, does the platter spin at a constant speed (33 or 45 rpm), or does it spin super fast? If it spins at a constant speed, and it just wont stop, replacing that pot should do the trick (VR201 can be purchased HERE). You can attempt to replace it yourself (soldering skills are required), or just buy the part, and have a service tech replace it for you.
If it does not solve the problem, then the issue is with one of the IC's (integrated circuits). This is a more complex diagnosis and repair. But try replacing VR201 first, then taking it from there.
- TERMiNAL OPTiC
www.DJPROLAB.com
Mar 03, 2008 | Technics SL-1200 Turntable
Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Oct 23, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1210 Turntable Logo
702 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
