SOURCE: Epson stylus photo 810 won't print
Is it just not printing on the paper and feeding it thru, or will it just not do anything? I need more info?
SOURCE: Epson Stylus C86 spits out blanks
As you have already done head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
