Belkin (F5D7230-4) Router (587009) Logo
Posted on Apr 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I moved my computer - unhooked the modem and wireless router and
When I hook it back up the wireless router does not allow me to connect the internet. I can unplug the wireless and get a direct internet connection to the desktop but when I hook the router up I can't connect. It's a Belkin 802 wireless g router
Anonymous
Level 1:
Spread the Word:
An expert who has shared 5 answers on their Facebook wall.
  • Contributor 55 Answers
  • Posted on Apr 17, 2012
Anonymous
Contributor
Level 1:
Spread the Word:
Answers
55
Questions
Helped
12236
Points
82
If you have matters about the laptop batteries,maybe the bestlaptopbattery.co.uk is helpful for you.
Anonymous
Level 2:
  • Expert 67 Answers
  • Posted on Apr 04, 2009
Anonymous
Expert
Level 2:
Answers
67
Questions
0
Helped
25203
Points
167
Powerdown the PC, router, and modem then start the modem first then the router and finally power-on the computer... That should do it! Hope it helps!
-- Joshua79
I had to unhook my d-link router DIR615 from my internet and my laptop because it stopped working with my dsl and it caused my desktop to not connect to the internet I have had problems with this router...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
I unhooked computer to paint walls. Now
I think you must be just unlucky.
I think the reset button just resets the wireless internet but I am not certain about that.
Usually when a router loses it's memory it needs a call to the internet service provider who will get inside it and reset the addresses and check the connections and so forth. This is usually necessary even if you own your own router rather than having one provided by the ISP.
Diagnostics says the router isn't connected to the internet so maybe that is the truth and the problem - coincidences do happen and maybe there is a fault somewhere on the line and it needs reporting to ISP so they can check it or get it checked.
It could be worth double-checking the connections and leads first. I recently had trouble with a phone that worked only when it felt like it. The trouble was a couple if pins in the master socket had gone green and was failing to make contact with the phone plug some of the time.
1helpful
2answers
Keep getting kicked off
when sharing internet connection, it's all about sequence when turning it on... Sequence in regard to what's turned on first, second etc... Here's the solution:
1. Turn everything off... modem, router...computers etc..
2. Turn on the wireless router FIRST and let it boot up.
3. Then turn on the modem and let it cycle up...
This allows your modem to lock onto the wifi router.
4. Turn everything else back on...
You should be good to go without drop outs...
If the power goes out, simply follow this sequence...
It's all about the sequence!!
Comcast unhooked it and i dont know how to hook it back up
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
2answers
Connecting a wireless router to Mac
Are you trying to set up router ?
You can set up your router manually, without the CD.
How do i reconnect linksys
Oh man your going to have to help me out a little on this one. Do you mean you had to unhook it and connect directly to the modem and now you want to hook the router back up? If thats the case Unplug all the devices (Pc's modem and router) connect an Ethernet cable from the ethernet port on the back of the modem (not the linksys) to the internet ethernet port on the linksys (usually set a little apart from the rest) then connect all the computers to the routers ethernet ports (usually labeled 1-4) then turn on power to the devices starting with the modem, wait for it to completely boot up all the lights like they're supossed to look. Then turn on the router and wait for that to finish booting up then all of the computers. If you have wireless devices that will take a little more help.
2answers
No internet signal from router in other ports
Hello, Under the wireless menu on router you must give a ssid name and enable and save to turn on wireless , hoe this helps?
Link Sys wireless G router, connects with laptop, not desktop
first unhook router and hook up pc directly yo modem and type in 191.168.1.254 and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
THESE ARE DSL INSTRUCTIONS
Reconnecting router
Connect your Internet provider to the WAN port
connect your COmputer to the LANPORT
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
