Which model ipod ??
In keeping with Apple's goal to make user-friendly,
streamlined products, the designers of the iPod built in easy-to-use reset
functions into each iPod model.
Resetting the iPod is similar to rebooting a computer as all
songs and data stored on the device stay there, and only temporary information
(such as which song is playing) gets reset.
Follow these steps to reset an iPod.
Toggle the "Hold" switch to the "On" position, then
"Off."
The "Hold" switch is the small sliding switch on
the top of the iPod.
Move it to the "On" position to show an orange
rectangle. Move it back to the "Off" position to show a white
rectangle.
Hold the "Menu" and "Center" buttons.
Press the 2 buttons at the same time for between 8 and 10
seconds.
Your screen will go blank and then boot up with a dark Apple
icon.
The icon eventually turns bright and brings you back to your
main menu once the reset is complete.
Check your iPod to make sure it plays properly. If the iPod
still does not work repeat the reset process.
Scroll Wheel and Touch Wheel iPods
Move the "Hold" switch from "On" to
"Off."
Press the "Play/Pause" button and the
"Menu" button at the same time.
Press both buttons together for approximately 6 to 8
seconds.
This initiates the self-running reset process.
Make sure the reset was successful.
If problems persist you may need to perform the reset
process once again.
iPod Nano
Move the on-off switch to the "Off" position that
shows the green strip.
Leave the iPod Nano in this position for 5 seconds.
Move the switch back to the "On" position.
Use your iPod Nano to
make sure the reset worked properly and all your music is intact.
