Fuji FinePix S5000 Digital Camera Logo
Anonymous Posted on Aug 06, 2013
No image displayed on LCD screen - Fuji FinePix S5000 Digital Camera
brian richardson
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 08, 2013
brian richardson
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
77
Points
21
I would like to know if this is fixable please anyone
St2410b no display
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/dell-n26397-lcd-inverter-p-5754.html
Desact monitor
When the following symptoms, that is, to replace a laptop LCD screen:
Display fades away and colores waile reading
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
More information in: http://lcdinverter.info/toshiba-lcd-inverter-c-13/
Laptop, display problem
Dear User..Does the Screen have a displayed Image?
If the laptop has no image at all it can be video card or LCD cable or the LCD panel. About the only non-invasive test you can try is to plug an external monitor into the laptop. This will determine if the problem is motherboard/graphics card or lcd cable/lcd screen. If you have an image on the external monitor then its likely to be lcd/cable/lcd screen.
Is the Displayed Image Faint?
A dim screen can be caused by three things;
1/ The LCD inverter which runs the LCD backlighting
2/ The CCFL backlighting fluro tube in the LCD panel
3/ The motherboard supplying signal & voltage to the inverter.
Thanks
7helpful
I have a problem about my laptop if i turn it on my screen are still blank but my laptop is still working.. can i ask if what is the problem about my laptop. pls help me... tnx!
Although your Toshiba portable computer appears to be on and running, there is no image on the built-in LCD display screen Look closely at the LCD display screen. If you can see a faint image on the screen, the display screen's fluorescent backlight may be turned off. Shining a flashlight directly at the screen will make it much easier to see whether or not there is a screen image actually present, though not lit up. On most Toshiba portable computers, there is a small plastic or metal pin near one of the LCD display lid hinges. When the display lid is shut (closed), this pin is pressed against an internal switch which turns off the backlight, saving battery power. You may be able to turn the backlight on again by tapping this pin repeatedly. The normal screen image will then suddenly appear, or re-appear.If there appears to be no display image at all, the problem is probably not related to the backlight. In this case, press and hold the Fn key and then press the F5 key several times, pausing several seconds between each keypress. This will cycle through several display output modes: Internal, External, Simultaneous, and possibly one or two more.If no image appears on the LCD display after cycling through the Fn-F5 sequence, try doing so with an external CRT monitor attached, if possible. If you still see no image, on either screen, try restarting the computer with the CRT monitor connected.If you see a screen image that looks normal when the computer is first powered on, or when you try to enter the BIOS Setup during the power-on sequence, it's an indication of a software problem (a driver or an application that's launched while the computer is loading Windows, possibly). Try downloading the display drivers for the computer from the Toshiba Support website, and then re-installing them.If the LCD screen or an external CRT monitor is blank only while the computer is first powered-on, but then works fine, it's probably not an indication of a problem. Some models display no text or images during the startup process. Additionally, installing some Windows Updates may delay the appearance of the familiar Windows desktop.If there are blank margins bordering the image on the LCD screen, launch the Windows Control Panel, then double-click the Display icon. Click the Settings tab, and then adjust the Screen Resolution setting until image fills the entire LCD screen, which will cause the margins to disappear.If the font size on an external CRT monitor seems too small for comfortable viewing, try clicking the Advanced button on the Settings page, and then adjust the DPI (dots per inch) value. Try 120DPI and 135DIP, to begin with. Avoid changing the DPI to much greater values, in order to avoid settings that will be difficult to change.
  1. Hold down the power button for approximately 10 seconds until the computer turns off.
  2. Verify that neither one of these keys are stuck in the down position:
    the Tab key (arrows pointing left and right)
    the tilde key ( ~ and ` characters)
  3. Turn the computer on.
  4. If either of the keys above appears to be stuck in the down position, and if the issue is not corrected by pressing these keys repeatedly, then service is required.
Problem is that when we open the camera white screen display on lcd ,no pictures display but movie recording is ok.
Connecting flexible cable between lcd board and main board of camcorder seems lose, open lcd cabinet and insert flexible cable in connector of lcd board properly to get image in lcd screen.
Below image shows flexible wire and connector on lcd board of MHS-CM1 camera.
Hope these info will help you.
Thanks.
My LCD TV has X-ray-like image on the half of the screen.
Looks like you have a bad Display Drive Board which drives the LCD display. Bad news is the Display Board is sold With the Panel.
Lcd screen does not display viewfinder image
That is normal. Didital SLRs are different in this respect from digital compacts .
JVC GR-D50E Digital video camera - on LCD view image is not displaying
if you live in very cold region, the mist or moisture give you this problem, using a hair dryer will solve this problem.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
