2001 V Tech engine runs full throttle in neutral or in gear
The engine runs full throttle in gear or neutral. The car cannot be driven in this condition. Accelerator appears to be normal, feels normal when testing with engine off.
Re: 2001 V Tech engine runs full throttle in neutral or...
Look under the hood. Look for the throttle body .The accelerator cable is attached to it. The cable housing anchor is broken and not letting it return to idle speed.. Use a portion of a clothes hanger to secure the cable housing to the throttle body.
I have the same problem with my harrier 3000cc car. We have changed the idling sensor, airflow sensor. air filter, we have had the throttle checked, spark plugs, wiring and nothing works. The smell you are getting could be from your gear box, have it checked out early and if the gear shift is noticeable then you will need a gearbox specialist to open it and change the clutch plates. Good luck.
Clean the Idle air control valve (IAC), it's located by the throttle body so the best thing to do is give the throttle body a good cleaning with throttle body cleaner. Do not use carb cleaner, it's to corrosive for the gaskets used on the throttlebody's. Just follow the instruction on the spray can and after your done putting everything back together. Turn the ignition key's to the run position for 10 seconds and then off for 10 seconds to reset the IAC. Start the engine and let idle for 1 min and go for a test drive. If that does not work, turn the ignition to the run position and pull the ecm(BATT) fuse out for 30 seconds and then place it back in start te engine. The engine may stall but let it, don't touch anything. Just start it again and let idle for 1 min then go for a test drive. The ECM is just relearning the sensors like the first time the jimmy was driven off the assembly line. Good luck and hope this helps. Keep me posted be glad to get your jimmy running 100%.
your torque convrtoer is shot. it is the at the front of the tranny to transfer motion from fly wheel ( engine side) to the trans. its a fairly cheap and easy fix.
most likely due to a stripped out torque converter or a broken pump shaft. trans. has to come out to repair either or. you should make sure the fluid is full first. with the car running and warm, check fluid- if it seems over full, the pump shaft is broken, if it's just full- probably the torque conv., if its low add trans. fluid (mercon 5) 1 qt. at a time until in crosshatched area on the dipstick. hope this helps and good luck
