Reformatted my laptop,reinstalled programs-now will not connect to wireless linksys router- will not accept access key--what gives??
Hi Drew,
I am assuming by access key your are referring to the pass phrase. The easiest way to approach this would be to use a cable to connect directly to the router from your laptop and confirm the wireless configuration on the router. You may have the pass phrase correct by the router is using WEP and your laptop is set to WPA or visa versa. Confirm the wireless configuration on the router then unplug the laptop from the router and change the configuration for you wireless settings on the laptop.
Thanks Rick- I will give it a try!
