Have the same problem been all over the web looking for driver for my NEC Superscripy 1260 and like others worked good until VISTA come along... has anyone found any cures as yet???Have the same problem been all over the web looking for driver for my NEC Superscripy 1260 and like others worked good until VISTA come along... has anyone found any cures as yet???
You can't post conmments that contain an email address.
I would say yes... Miracle. You can attempt (if this printer will support HP emulation) and I think it does. Simply, choose the "HP Laserjet 4" driver (as generic as possible) you may be able to get it to print.
The NEC SuperScript 1260 has a parallel printer port. So you would need a parallel to usb adapter. These aren't very expensive; depending on the brand and length you'll pay between $8 and $15. See https://www.amazon.com/TRENDnet-Parallel-Converter-10-6-10-9-TU-P1284/dp/B0007T27HS or https://www.amazon.com/Sabrent-Parallel-Printer-Adapter-CB-CN36/dp/B00IDU0T1Y Alternatively, if you have a desktop, you can find a PCI or PCI-e add-on card with a parallel port, depending on the slots available in the system. These will be closer to $20 to $30. Then you need a standard parallel printer cable. Many computer parts sites, including Amazon.com, will have both.
A bigger problem may be the printer drivers. NEC did not update the drivers after Windows XP. (Some XP drivers will work under Vista.) NEC doesn't supply the drivers on their site: https://support.necam.com/Printers/Drivers/ . They refer you to the original driver CD that came with the printer. A few sites may have these drivers online. However, I haven't seen a link to a known trust-worthy site with the XP driver.
I hope this helps. Please add a comment if you need more information.
This has been a problem since XP. However I found that if you install HP Laserjet IIp drivers the printer WILL work in Vista! You won't have all functions but at least it is very suable. Hope this helps!
