Singer 3116 Simple Logo
Anonymous Posted on Aug 06, 2013
Pattern calls for 3/16 seam allowance. What is that in comparison to the marks in my machine?
Kelley Buchanan
Level 2:
  • Expert 130 Answers
  • Posted on Sep 01, 2013
Kelley Buchanan
Expert
Level 2:
Answers
130
Questions
Helped
91933
Points
321
Well, the normal seam allowance is 5/8ths. Always has been except on crafts and doll clothes. 3/16ths is 1/3 of the normal 5/8ths so I would think, now wider than the width of your sewing foot.
2answers
I am making simplicity pattern #1800. I want to know if you use the one inch seam for everything?
Hello, Kathy -
Doesn't the tissue pattern for the garment you wish to sew have seam markings on it, indicating the seam allowance?
See image 02 here:
https://www.thesprucecrafts.com/techniques-for-sewing-clothing-2978471
It shows an edge of a pattern piece with the seam allowance printed on it.
It has been a long time since have sewn garments, but I recall that unless the pattern indicates otherwise, seams are sewn at 5/8 inches. If the pattern indicates 1 inch seam allowances and no other seam allowance depth, then, a 1 inch seam allowance it is.
I do not have Simplicity Pattern #1800 myself. If you do not have the printed sewing instructions for the pattern (where the seam depth may be stated), then you may wish to contact Simplicity Creative Group and ask to purchase replacement instructions for your pattern.
This is the US toll free phone number to call:
833-201-5260
To send an email, this is the link to the web page with a form you can use to fill out to ask about the availability of replacement instructions:
https://www.simplicity.com/contactus/?topic=OTHER
Best wishes.
Burda pattern 6921 Please can you give me information on how to make the lining for this jacket?
Um, that may be difficult to explain. Generally, you would have facings all around the open areas. Then use the same jacket pattern to cut out the lining, BUT be sure to add a double amount of seam allowance for stitching the facing to the lining.
http://www.threadsmagazine.com/item/4366/bag-your-jacket-lining/page/all
https://www.youtube.com/watch?v=t3u4-ylDMv4
https://www.craftsy.com/blog/2016/03/lining-pattern/
How do I add knit band to pajama pant on McCalls pattern 7975. I have lost the directions.
Usually the cuff ribbing is cut double the required length plus doubled seam allowances (ie 3" x 2 = 6; add two 5/8" for seams = 1.25"'; equals 7.25" long). It is doubled so when it is folded in half and stitched to the leg, there will be no seams showing outside). The width of the ribbing is probably an inch or so shorter than the leg bottom--it should be large enough for the foot to fit through but tight enough that it hugs (not squeezes) the leg.
Sew the cuff together lengthwise to make a circle. Fold it in half with the stitched seam inside. Then fold the circle widthwise with the seamline at one end. Mark the halfway point opposite the seamline. Then fold in half again with the seamline and the first pin matching together. Mark the other two ends. You've divided it into equal fourths. Repeat the same procedure marking the pajama leg in fourths. Then match the seamline of the ribbing to the seamline of the leg (right sides together). Match the other three marks on the cuff to the three marks on the pajama leg bottom. You'll have the stretch the ribbing because it should be a bit smaller in circumference than the leg bottom. Stretch the ribbing to match the leg bottom and stitch the ribbing and leg bottoms together. Turn right side out.
How to Attach Knit Cuffs to Sleeve Shirt Sleeves
sewing with knit fabric how to sew sleeve cuff with knit fabric
I lost my instructions for pattern 5527 (diaper bag). Can you help?
You could contact Simplicity and see if they can help.
or find a free diaper bag pattern on line and use as a guide.
bags arent too difficilt, usually need to interface well, attach pockets, straps, then sew lining to top edge wrong side to wrong side, leaving a bit of the lining or side seam open so you can get inside to attach lining seam allowances to bag seam allowances to hold together.
Simplicity 5527 Diaper Bag in Three Sizes
1helpful
How do I adjust the seam allowance to cut 1/4 inch
Hello
To the right of the cutter, on the front cover, there are markings indicating various seam allowances. Placing the fabric edge along the specific seam allowance will automatically cut off the required amount of fabric and the serged seam will be on the seam line. Do a test sample first to ensure that the marked lines refer to the left needle or to the single needle that you are using.
Yes, there is a blade position dial too. It is located closest to you on the left side on the bottom. The larger the number, the wider the seam. Again make a few test samples to ensure the results that you are seeking.
Happy stitching.
What are the seam allowances 1/4 3/8 5/8 lines?
they are guide lines for when you need to sew a 1/4 inch seams
allowance.
or if the pattern calls for a 3/8 inch seam allowance then you have a
guide line to go by.
some people use them when they sew and some people don't use
them when they sew.
3answers
Need help with seam guide? there are no numbers, how do i know what each line measures?
Firstly you need to ensure your needle is centred, remove the presser foot for a bit of room, lower the needle down into the needle plate, and then measure from the needle to the right to each marking on your needle plate.
If you are in the USA, then I'd guess there would be three markings at 1/4" 1/2" and 5/8". Quarter inch is your narrow seam for quilting but if you are sewing garments, then the seam allowance is usually 5/8", it would be marked on your paper pattern though. Some patterns such as Burda came with no allowance and you need to add them on, again it would be marked on the pattern though.
If you are in a metric country, then it will probably have 10mm, 15mm and 20mm marked. Normal seam allowance is 15mm.
If you have trouble remembering which marking to use, you could always stick a strip of masking tape onto your plate along the line you use for seams until you get some sewing experience.
You might like to visit www.sewing.about.com, Debbie Cosgrove gives loads of very useful information there, a learn to sew page along with some free projects. At the tender age of 10 I recall sewing an apron and triangle scarf in home economics as my very first project on an Elna Star SU, simple projects are best when starting out.
If you are going to sew garments, then you may also like to check out www.patternreview.com, I love this site as members share their experience with commercial sewing patterns, some very talented sewists there; many of them have their own blogs too.
If you can find a sewing beginner class, take it, it will get you started with basic techniques that patterns don't really give you and help with that initial learning curve. And my last suggestion, invest in a good sewing textbook; I've got the Vogue Book of Sewing, and also the The Sewing Book by Alison Smith published by Doring Kindersley; I love this one, loads of great images and its a fresh publication. Bit pricey but if you could always ask a loved one to buy it for Christmas. Feel free to connect to me if you have any other sewing questions, I'd love to help.
Happy sewing
Quilting seam allowance
When you turn your machine on it automatically sets up for a straight stitch with the needle centered. Just guide the right edge of your fabric along the line marked 15 on the throat plate and you'll have very close to a 5/8" seam. If you need more precision you can adjust your needle position to the left or the right by using the stitch width and mirror setting buttons.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
