Question about Home Fencing
Wire motor to stanley auto gate
Wire diagram to the gate from motor. i have both diagrams but still lil confused
Posted by Guy Mitchell on
michael
    New Friend:
What exactly is your problem i have a gate system aswell
Posted on Aug 09, 2013
Automatic gate with photocell sensor
The control board should have designated terminals to land the protocol sensor wires. What do you have, any wiring diagrams, instructions.
The photocel is probably wired into wrong terminals
Nov 09, 2017 | Cars & Trucks
I have a haldex 1hp 115/208-230 volt motor ac. i need to make sure i hook it up right for 230 power. the diagram just confuses me and im a mechanic. white wire, black wire, push button switch, and 7
the spade terminals in the wiring box are marked the chart tells where the color wire goes to what terminal for what voltage then l1 and l2 is the incoming power hookups
Sep 09, 2014 | Heating & Cooling
Need diagram for hooking up #252 Lionel Crossing Gate
Here's a link to the Service Manual to the 252 Crossing gate.
http://www.lionel.com/media/servicedocuments/71-2714-250.pdf
Dec 31, 2012 | Lionel O 27 252 Auto Crossing Gate
Mangled wire in window motor for 2001 chevy suburban.
You can replace the original damaged wires by soldering
in & heat shrinking new ones
Just match what is damaged
If you get really confused or have issues other
than visual damage,then you will need a wiring
diagram
Dec 12, 2012 | 2001 Chevrolet Suburban
What is the blue and yellow wire on the wire harness for the kenwood kdc-138?
According to any wiring diagrams I have looked at for the radio in your vehicle (both the premium and base systems), the only wire that I see that could get pretty much anyone confused unless they know is a dimmer wire coming from your headlamp switch. The only reason I cannot be 100 percent sure is because according to the wiring diagrams it is a black and yellow wire but I don't see any other wire with yellow that could cause a question. To be sure you can always check at the connector on the headlamp switch and check for continuity but if I were a betting man I would put my money on this. I went on and gave you the wiring diagram for the base system (without an amp). Not sure how well you can see anything due to a size limit on pictures but I hope I was able to help.
Dec 02, 2012 | Kenwood KDC-138 FM / AM Receiver
1996 aerostar solenoid wire diagram
you need a haynes repair manual, you can buy one at any auto parts stores like auto zone, advance auto parts.
Sep 01, 2012 | Cars & Trucks
Do you have a wireing diagram for a 1996 s10 pickup with a 2.2 motor a automatic trans ?
Posting wire diagrams would be illegal since it would violate a copyright. You can pick up a Hanyes or Chilton auto repair manual for your truck at a local auto parts store. It will have your wire diagrams in it.
Dec 05, 2010 | Chevrolet S 10 Cars & Trucks
Wire diagram for a 1993 cadillac eldorado radio
Easiest way. Go to any auto store, Pep Boys etc, locate the book for the year of your car and write down the wire diagram.
Sep 10, 2009 | 1993 Cadillac Eldorado
Need to install power cord to terminals on 220 AC motor
Ok, read the data plate on the motor. Does it have a zero with a line straight through it. That means it's single phase. Also the plate may list two different voltages 110/220ac correct. On the inside of the panel of the box where the cord connects it will have a two diagrams. One marked low voltage, the other high voltage. You want 220ac so follow the high voltage diagram. Since it's single phase the green wire will go to a green screw in the box. The black wire from your cord is positive and the white negitive (actually neutral but shown on diagrams as negitive). The wire coming out of the motor will have numbers on it's casing. Follow the connection points on the diagram. Don't worry if you hook them backwards the motor just won't turn. It won't hurt anything.
Apr 02, 2009 | Coleman Powermate 60 Gallon Air Compressor
Wiring diagram
ok, try purchasing a Chilton Manual (NOT a Haynes- it's junk). In it you'll find the complete wiring diagram.
Aug 03, 2008 | 1998 Ford Escort
Home Fencing Logo
1,721 people viewed this question
Top Home Fencing Experts
Tom Chichester
 Russ Hill
Russ Hill
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
