Question about Logitech Radio Communications
Electric shock In using my headset for Dragon Naturally Speaking, I heard a buzzing sound and then felt an electrical shock on my ear. It was frightening and painful. Is it possible to receive electrical shock from a headset? (it is plugged in by way of jacks).
Posted by Kelly Robbins on
Shari Cornell
    New Friend:
Did you ever find an answer to this? We have had a couple of agents have this happen to them also just this week. I would like to know if it's the headset or something else.
Posted on Jan 24, 2014
2 Related Answers
muebe
  • 1015 Answers
SOURCE: In recent days my headset (590A) has only been
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
Posted on Oct 15, 2010
Anonymous
SOURCE: Compatibility with Dragon Naturally Speaking
This problem was not fixed. Agent gave up on me and disconnected
Posted on Oct 03, 2008
Dragon Naturally Speaking Playback is not working with Word document.
This link would better explain your issue and has the best solution.
Ihope that will fix the issue...
Dragon Naturally Speaking Playback is not working in Word document
Jan 19, 2018 | Dragon Computers & Internet
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
Apr 25, 2013 | Nuance Dragon Naturally Speaking 11 Home
I just bought naturakl speaking 11.5 home. how do i download it/
Dragon Naturally Speaking 11.5 FULL
If you already have a premium key,
Click here
Aug 29, 2012 | Nuance Dragon Naturally Speaking 11.5...
Trying to use the headset provided by Dragon 11 naturally speaking software. The headset has two jacks, a mic and a headphone one which I have set up via RealTek, although I cannot get playback on the...
Did you check the installed sound devices on the computer?
May be you do not have any sound driver installed on the computer,
Also check the device is not disabled from the control panel.
If you did not find the solution helpful. Try to search for the solution here... this has many solution to this problem.
Nuance and Dragon Naturally Speaking Support
Jun 18, 2017 | Nuance Dragon NaturallySpeaking 11 Premium...
MY DRAGON NATURALLY SPEAKING 10-PROFESSIONAL DOES NOT WORK IN AOL EMAIL. IT WORKS WITH EVERY OTHER PROGRAM. BUT, WHEN I TRY TO DICTATE IN AOL EMAIL, NOTHING HAPPENS. ANYONE KNOW OF A SOLUTION?
Dragon Naturally Speaking 10 has not been tested to work with web based e-mail. It's also the same thing with Dragon Naturally Speaking 11 regardless of any version. As a work around and fix for this, if you want to use it through on any web based e-mail is to use the Dictation box.
Here are the simple steps to access the Dictation box:
1.Make sure you have successfully loaded a working user profile. 2.On the dragon bar, go to tools and then go to "Dictation Box" 3.Here, you can start dictating e-mail messages and use the "Transfer" button to transfer text in AOL E-mail.
I hope this solves your current problem.
Jun 05, 2010 | NRS Nuance Dragon Naturally Speaking 10...
Oct 02, 2008 | Andrea NC-7100 Consumer Headset
Radio Communications Logo
66 people viewed this question
Top Logitech Radio Communications Experts
Ekse
Marvin
Marvin
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
