Question about Audiovox Televison & Video
Try to program a remote for an audiovox 5 disc cd changer/radio. model # E58348
Posted by jodie donahue on
5 Related Answers
Anonymous
SOURCE: Need programing guide and codes for a Jensen 6-device Universal Remote (Jer622)
I have this remote...only Pioneer listings are as follows: TV: 1004,1006,1089 VCR/DVR: 2010,2055,2071 DVD: 3312,3311,3287,3286 To program (for example TV setting): Press and hold down TV while entering code i.e. 1-0-0-4 To manually cycle through all codes (example for TV): Press and hold TV while pressing and holding ON/OFF, after 3 seconds the on/off button light should come on and stay on - release all buttons. Turn your TV on and press ON/OFF once each 5 seconds until your TV turns off. When it turns off, you have the correct code - press the stop button. Good luck.
Posted on Feb 18, 2007
Anonymous
  • 326 Answers
SOURCE: I can't get the remote to work with my disc changer
Hello, please check the batteries by replacement (use fresh ones). Best regards, Arpi
Posted on Apr 06, 2007
Anonymous
  • 4 Answers
SOURCE: trying to program my Radio Shack 15-2147 remote to my emerson tv
I need the Sony TV code for 3-in-one remote
Posted on Dec 14, 2008
Anonymous
  • 16 Answers
SOURCE: Chevy Equinox 5 disc cd changer. Car battery died which cycled cd changer several times. Now it just gives cd error message and I cant get the lone cd out and I cannot load a cd.
make sure your alltanator is chargeing from the battery,how you can do that start the car open the hood and take one of the batter cable if the car still run,that means the alltanator is good,if the can turn off when you take the
Posted on May 11, 2009
Anonymous
  • 382 Answers
SOURCE: jvc xl-f254 cd changer for home. 5 disc
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Posted on Jan 29, 2010
How can i program the CDC-565 without a remote?
Unofrtunately there is no way to program this changer without the remote, as their buttons allow only selecting tracks between discs when they are being played.
I have 3 wires one direct to battery one ground what is he 3rd wire go to
perhaps is the ignition or a remote terminal.try to connect it to the acc+ of yur car
1helpful
2answers
Will the Audiovox SP-6cds hook to an Audiovox GM250 radio?
Yes - the radio has cd changer controllers.
The Changer is FM modulated - and the radio becomes the controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
I am looking for an Audiovox MVCH10A 10 disc DVD/CD Magazine. Can anyone help me locate one??
I am looking for a remote... if I cant find a remote I will sell you the unit if you are interested?
6helpful
3answers
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Need remote control
hi there,
use ebay as a browsing tool to look out for the remote. or if you contact the manufactorer they will be able to help you
My Clarion 6cd changer Say's Err #9 ?
This means Weak Radio Frequency.... try changing the radio frequency, and you should have no problems :D.... Please rate answer... and i wish you the best of luck, because i know from experience that audio equipment is not cheap... ask questions if you have anymore :)
2answers
Problem with 6 disc changer
Hi I believe it is tellinng you that you do not have a disc Jacket. The case that holds the 6 discs. If you have this the switch inside the CD changerneeds some investigation.
Televison & Video Logo
Top Audiovox Televison & Video Experts
Ekse
Raj Patel
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
