Question about Sharp Aquos LC-45GD6U 45 in. LCD HDTV
New Boards Needed for Sharp LC-45GD6U
Can anyone recommend an inexpensive place to purchase boards for my Sharp LCD. The repair guy said I need two new boards (I have the part numbers) that will cost $1,200 without labor. Are there aftermarket boards that I can try? Thanks for your help.
Posted by ethan_butter on
  • 1 more comment
  • ethan_butter Apr 03, 2009
    The model number is LC-45GD6U. I have the part numbers of the boards needed but not with me. Can I get back with you later?
    Many thanks. I am getting a lot of grief from the spouse for spending nearly $5K on this 4 years ago and not being able to get it repaired cheaper than we can buy a new one now.
  • ethan_butter Apr 23, 2009
    I have the part numbers for the boards that I need for the Sharrp LC-45GD6U. Any help you can provide in locating a source for these parts would be appreciative.
    Main Unit - DUNTKD003VJ02
    Digital Unit - DUNTKC307VJ38
    Thanks!
Anonymous
I have one that fell over and the screen broke I can part out. [email protected]
Posted on Apr 30, 2009
Jaime Hernandez
  • 2,337 Answers
You might not be able to find aftermarket parts but you can find used boards that have been removed from broken screen LCDs.
What is the model number of your LCD or the part numbers of the boards?
Posted on Apr 03, 2009
  • Jaime Hernandez Apr 03, 2009
    Write back with the part numbers and we will see if we can locate a supplier.
    You can also search for the parts here or call them once you get the board part numbers.
    Good Luck.
My Sharp Aquos TV will not turn on...just a green ligth flashing...something to do with power...how can i fix it?
The most common issue on these is the power supply boards. Bad capacitors on these boards are the issue and there are repair kits available if yur qualified for the repair other wise you can get new boards and swap them out. This is the most common issue in the business right now. Sharp sets are a little different in ther design on the power supplies but parts can be had and repairs can be made. You will need to balance the price for the repair vs a new set. Just Google TV power supply repair kits for Sharp Aquos and you will find repair kits and information on the power supplies.
If this was helpful a vote on the thumbs up would be greatly appreciated for the free advice.
Aug 22, 2011 | Sharp AQUOS LC-42D43U 42" HDTV LCD TV
My Sharp LC-45GX6U gives only a white screen when I turn it on.
Can you guys please elaborate on what the work-around was for this issue?
Feb 19, 2011 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
I have a non-functional Sharp LC-32D62U (32") TV.
It would be possible if you can go into service menu and write all settings and implement with the new board by going back in and changing what you wrote down.
Feb 17, 2011 | Sharp Aquos LC-32D62U 32 in. HDTV-Ready...
The audio on my LC-45GD6U goes in and out (mostly
if its fine on other channels i would not suspect the tv
Aug 26, 2009 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Color pulses after LC-37D62U has been on a while
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
Feb 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Nov 06, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Open Questions:
Sharp Aquos LC-45GD6U 45 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
