SOURCE: How do I unlock the Canada maps?
I had same problem, purchase Sd card, because internal memory too low for all Canada and Usa. search thepiratesbay.org for unlocker program. It works like a charm. Ps i dont know the legality of using unlocker so you may want to consult Garmin.
SOURCE: Garmin 350 won't let me enter City/Postal Code
I had the same problem with new UK postcodes. My maps are v9; v11 is current standard. Garmin told me that for commercial locations you can find the premises in Google maps and then use the "send" facility that appears at the top of map to send location via usb connection to your Garmin. You may have to download an Activex control. Hope this helps
SOURCE: Garmin nuvi 200w can't update all 49 lower states
OK, I just finally am getting through all of this myself.
First, the bad news. You cannot load all of the lower 49 states onto your Garmin 200W as-is. The map file is over 1GB and the 200W only has 991MBs of memory.
So, go out and get yourself a SD card. I got a 2GB card at OfficeDepot for $8. It was at the counter, not back with the other cards they carry (Note: The speed showed as 60x. The slightly more expensive ones, $12-$15, may be faster, like 150x.)
You'll also need to get yourself MapInstall, available from the Garmin site. BUT, don't try to use this right away, a mistake I made. If you do, you basically get a message that MapInstall can't be installed because it's not already installed. Seriously.
BUT, MapInstall GETS installed, or whatever, when you load your 2010 maps (or partial maps), so after you do your partial install, THEN you can install the MapInstall program. (May not be necessary, but remember, I did this out of order. Look for a "Garmin" folder under your Programs, or All Programs, and see if it's already there after you install your 2010 maps.)
Next, run MapInstall. The next mistake I made was that at the window where it finds your device, I clicked on the NEXT button. DON'T. Notice that your device is shown in a drop-down box. Click on that, and you can select your SD card for the destination.
THEN click NEXT. On my system, it appears as if it shows you what IS already on the 200W, and lets you select whatever you want to add. I put everything else available on the SD card.
I just this minute finished loading "the rest" and checked it out. Works flawlessly. I easily found a seafood restaraunt in Anchorage (Alaska was not loaded in the intitial install.)
Just remember that you have to keep the SD card in the Garmin at all times to use those maps. That really shouldn't be a problem though.
Hope this helps eveyone.
JDCrownover
Huntsville, AL
SOURCE: When I press Address, then Spell state, the screen
Please see this link. Your map is turned off:
http://www.sharc.net/discus/messages/6/75.html?1239690151
- Jim
SOURCE: Describe your change state/province setting garmin
Once you click Where To at the bottom of screen click Near
choose Where I am now ..... A different City....Current route or Destination
