Sanyo SR-3620 Compact Refrigerator Logo
Anonymous Posted on Aug 05, 2013
Fridge freezes everything - Sanyo SR-3620 Compact Refrigerator
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 93 Answers
  • Posted on Aug 05, 2013
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
93
Questions
0
Helped
19360
Points
255
Try lowering your thermostat setting, if the thermostat does not ever shut off the fridge your most likely have a defective thermostat.
My refrigerator is freezing everything I changed the door gaskets but it us stll freezing sny suggestions
If the freezer is freezing everything, check the coils. A refrigerant leak will cause ice to build up on the coils, not extra ice in the fridge. ... A leak in the compressor or coil will chill the air around the leak as long as it is outside, but a leak into the fridge could cause it to get extra cold.31 Aug 2015
How to Fix a Refrigerator that Freezes Everything - YouTube
https://www.youtube.com/watch?v=gXMJYv6kzKg refrigerator is freezing everything Google Search
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Whirlpool fridge ed250fwhx freezing everything
Your model should be ED25QFWHX and all you need is to replace the refrigerator thermostat you can see also all the parts diagrams of your fridge to the above link
2answers
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
2helpful
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Fridge is freezing everything!
There is a flap that directs the air from freezer to fridge. Sometimes this flap can stick Or the actuator that controls the flap can go out. Same with autodefrost timer which seems to give a lot of people trouble. Thermostat is at the top, uncirculated cold air sinks, food in the bottom of the fridge freezes.
2helpful
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
3helpful
2answers
Fridge freezing everything
If your fridge is freezing to much put the thermistor closer to the fins (it will make it colder so it shuts off sooner)
Danby compact 482 fridge is freezing everything. thermostat switch seems to check out.
Hello tbrown7777
Welcome.
You said, Your Danby compact 482 fridge is freezing everything. thermostat switch seems to check out.
Just 482 is incomplete!!!!!!!!!
Can you send me the complete model number off the sticker in the fridge or on the rear of the fridge?
and the year of it! waiting your response!
Huuum
Top Sanyo Refrigerators Experts
NOEL
NOEL
john h
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
