Question about Suburban Mfg Co Water Heater Direct Spark Ignition 6 Gallon
Hot water heater starts for about 5 to 10 sec then gos out r
Posted by dale on
Rizwan anwar
    New Friend:
Replace hot sensor
Posted on Apr 23, 2018
Don Keystone
    New Friend:
  • 4 Answers
Gene Haynes
  • Suburban Mfg Co Master
  • 5,391 Answers
Copy following link for possible surburban water heater resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Aug 05, 2013
Drain hot water heater
turn off gas
turn off cold water to heater
connect hose to spickot
place hose end outside
turn on spickot
open hot water faucets in house
wait.
when water stops, turn on cold water for 30-60 sec or so to try to stir up any sentiment in tank
turn off cold water and let drain.
close spickot
turn on cold water
let fill till water start coming out hot water faucets then turn off hot water faucets.
turn on gas and relight pilot.
finish bleeding air from hot water faucets.
set water heater thermostat
Jun 14, 2014 | Rheem 43VP50E2 50 Gallon FVR Natural Gas...
Water takes 30 sec to cover 10m from heater to tap
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } You are talking about length of time to get hot water from water heater.What diameter pipe are you talking about? What type of faucet do you have?
1/2" pipe has inside diameter of .54" and holds 1.2 gallons per 100 feet
10 meters is 32 feet and holds .4 gallons
Average faucet puts out 2 gallons per minute, so 30 seconds you should get 1 gallon of water.
Put a bucket under faucet and check amount of water flow.
Assuming you draw just hot water from the faucet, then 30 seconds is slow for receiving hot water.
If you have single-handle faucet and raise handle straight up in middle, then you are drawing half hot and half cold, so it would take 30 seconds for hot to arrive.
If hot water is slow, the problem might be crossover.
http://waterheatertimer.org/Crossover.html
or low water pressure due to clog in water line
http://waterheatertimer.org/Low-hot-water-pressure.html
Other problems could include clogged water filter, clogged water softener, defective pressure valve, and low water pressure.
Sources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
Jul 10, 2011 | Bosch Outdoor Gas Tankless Water Heater...
I have a gc6aa-10e hot water heater. I only get about 40 sec of hot water. I have raplaced check valve and put new thermostats in the water heater. I really dont know what else i should check. Need help...
Here is website for brochure and support center. http://www.atwoodmobile.com/water-heaters/atwood-water-heaters-brochure.asp
If it's electric it sounds like the elements.
Apr 23, 2011 | RTO Atwood Water Heater - 6 Gal LP
My 2007 Fleetwod ##0 FKDS TT has no hot water delivery, (cold is Fine) No water comes from any faucet (3), or shower(2). When hot water is tried a short squirt of water (Les than 1/2 sec ond) comes out and...
Check for faulty (broken/apart inside) and replace check valve on hot side of tank (top line) between line connection and tank. Stem, spring etc, of new one goes in facing into tank.
Jul 18, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have the 2700es and the water upstairs gos hot then cold ,hot then cold and so on , what sould i be looking at?
The water temperature may be set too high, or try turning the hot water off and opening a hot water tap. If the water is still flowing out the hot water tap, there is a problem with a faucet (likely a shower valve). It could also be water pressure below 30 psi.
Mar 28, 2010 | Bosch 2700ES Natural Gas AquaStar ...
No hot water. Gas co. serviceman says problem with draft inducer.
try to remove pipe you could have a clog water,ice,nest. also you may have a bad pressure swith hose find the hose and **** to see if it will fire
also if you take your pipe of you make turn on to see if you get fire you can not run for more then 30 sec with this off co. will fill the house.
Feb 13, 2010 | Fasco GSW Hot Water Heater Exhaust Draft...
The DSI fault light gos on but I still get hot water on electric but the light still gos on after a half day. The gas will not ignite at all.
CLEAN THE CONNECTIONS AT THE CIRCUIT BOARD WITH A PENCIL ERASER. MAKE SURE U HAVE 12V POWER TO BOARD. IF AFTER CLEANING AND THERE IS POWER, BOARD IS BAD.
Dec 16, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a johnson & starley 25-30 modairflow
I have resently had the same problem.
called british gas to inspect the system and they found that the flue had corroded at the vent and become detached allowing corbon monoxide fumes to enter the roof space and filter down the heater causing it to cut out.
advise you to stop using heater imidiately and call for assistance befor you are all gassed.
Nov 25, 2009 | Water Heaters
Suburban Mfg Co Water Heater Direct Spark Ignition 6 Gallon Logo
338 people viewed this question
Top Suburban Mfg Co Water Heaters Experts
Gene Haynes
David Spradling
David Spradling
Are you a Suburban Mfg Co Water Heater Expert? Answer questions, earn points and help others
