Question about Kirby G6 Bagged Upright Vacuum
Shampoo does not sud
Equipment attached right, shampoo to water ratio good. turn on machine, fluffer bringing dirt to tray, turn on suds flow and does not suds at all. used to suds entire width and bring dirty foam back to tray, now just sending mixture into rug, not picking up water or dirt.
please help.
thanks
Posted by rosemac1 on
  • rosemac1 Apr 10, 2009
    It is not dispensing suds. It seems to be dispensing the water soap mixture in a heavy single line, soaking the carpet in that one line and nothing else. there are no suds at all.
    thanks for you help, RockyNR1
    Have a great Easter celebration
    Rose
  • Rocky
    Rocky May 11, 2010
    Does it dispense suds but not picking up or it dispenses soapy water no foam?
Rocky
  • Kirby Expert
  • 324 Answers
The suds screen is not there or is somewhere in hose elbow. Click HERE and read the tip about installing the suds screen.
If you want to see where the screen is supposed to be installed - see out Kirby shampooer manual HERE.
Good Luck
Rocky
Posted on Apr 10, 2009
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby not shampooing, no suds coming out.
Make sure the tray is all the way down. Step on the toe petal to adjust. Turn on power assist.Turn sud control valve right to increase suds.
Apr 27, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to attach Kirby Heritage Suds-o-gun?
To use the suds-o-gun you need to convert you Kirby to blower mode. First remove the carpet head.
If you have all of the standard kirby attachments there should be a plastic cover to go over the front of the kirby where the carpet head attaches. Its round with square holes in one end. If you don't have this no biggie. Just leave the carpet head on the machine and rotate the belt to the off position so the brush rool bush on rotate. Remove the bag for the machine attach the hose where the bag was use the same end that attaches to the front on the machine. There are notches on the inside of the hose connector the fit over the tabs on the bag port. Fill the suds gun tank with shampoo and water. Attach the suds gun to the kirby hose. The suds gun nozzle is funnel shaped with wire mesh on the end. This helps to make the suds finer. Also the suds gun should have a knob to set how much suds come out when you pull the trigger. Turn on you kirby and suds away.
I hope this helps.
Feb 05, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 attaching fluffer brush on shampooer
Sure can,
You have two choices,
1.) To use your shampoo attachment, you'll need the fluffer shield, To set up the attachment seperate the tray assembly (the part that holds the roller brush) from the nozzle assembly (the part that attaches to the machine). Now seperate the roller brush from the tray (easiest way is to pull the belt). Insert the roller brush into the fluffer shield (it only goes one way). Insert the fluffer shield with the roller brush installed into the nozzle assembly the plastic shield will be faced towards the front of the machine. Turn belt lifter to where the red arrows match and attach to the front of the machine. Turn belt lifter to where the green arrows match and you should be in business.
2.) Your using the floor buffing attachment it the easiest method just put on like the floor nozzle (thing you vacuum with).
Jul 21, 2008 | Kirby G6 Bagged Upright Vacuum
Shampoo stairs
There is a portable shampooer/sprayer that attaches to the hose ( the long one that makes the kirby a canister vacuum). It should have come with your attachments. Looks a bit like a gun without the tank attached to the bottom...the tank screws on.
To use it you would put the fingerguard attachment on the front of the kirby where the powerhead would normally go and the hose with the portable shampooer where the bag would go.
The tank on the portable sprayer/shampooer has lines to indicate how much water and shampoo are needed.
Be sure to put the mesh nozzle (sort of a triangular shaped thing with a piece of mesh along the front that attaches to the front of the portable sprayer) on the front of the portable sprayer if you want to shampoo..otherwise it will just spray a mist. The triangular piece with the mesh screen is what produces suds.
Vacuum the furniture/stairs thoroughly before shampooing. Cover the stairs/furniture with a thick coat of suds. Once covered with suds, pop the suds into the fabric/carpet using your hands...working the bubbles into any heavily soiled areas with a soft brush. No need to vacuum after shampooing. There is only about 10 percent water to 90 percent air in the suds.
Then let it dry. 15 minutes to and hour depending on the amount of solution used. Hope this helps!!!
Feb 23, 2008 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby Ultimate G Series. I have misplaced (no, it's not lost...I have it somewhere) the manual. How do I use the upholstery attachment? Does it hook to the outlet on the shampoo tank?
Hope this helps!!!
Feb 14, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Intructions?
Yes indeed the processes is very simple.
You're going to take the front end off like you normally would, but you also need to detach the bag so you will then grip on to the handle under the mini emptor, that's the plastic thing is connected to, there is a grip under that you will grip and turn it towards you.
Once it's loose you will then fill the shampoo tank. The solution calls for one shampoo tank cap full of Kirby suds to one part of water, and you can find the water parts labeled on the side of the tank. Use ONLY Kirby suds, I've tried other brands of suds and they didn't dry as fast as Kirby does and Kirby smells better anyway.
Second you want to put the tank on the exhaust port of the Kirby where you took the bag off. You will see there are little buds on the port mouth and there are grooves on where the shampooer tank attaches to the port mouth, line the bud up with the grooves on the tank and push towards the handle.
Next you're gonna hook up the shampoo tray like you would the beater bar. Next you're going to hook up the shampooer hose and you will put the smooth end on the small port on the tank and the other end on the hole in the middle of the tray.
Then you should be ready to go all you do then is turn the vacuum on without the suds on, and put it all the way down. Then you turn the suds on full blast and put the vac in drive and go. Not too fast but not too slow either just go a bit slower then when you vacuum on back and forth strokes. Well, hope full this solves your problem!
Nov 19, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
249 people viewed this question
Top Kirby Vacuums Experts
Paul Bade
Marvin
Marvin
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
