<utube src="wVy8e0CSmy4"></utube><br>How to assemble and use your Dyson DC39 or DC37 vacuum cleaner. This applies to all variants supplied with the Musclehead floor tool.
If you'd like further help from our experts after giving this a try, please get in touch with us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we can also confirm if this is covered under your Dyson parts and labour guarantee.
I'm sure we can help with some advice on cleaning and maintaining your DC39, but can you please confirm if there's a specific part of the machine you need help cleaning? The advice will differ according to which part of the vacuum you're concerned about.
Alternatively, you're welcome to call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Remove brush bar cover...is the belt broken, cut or stretched to the point of being ineffective? Is the brush bar full of hair or string?
Pull the belt forward...does the pulley spin? Turn the cleaner on
and see if the pulley spins...if it does I think a new belt will be needed.
Be sure to buy the right one.
Like most Dyson vacuums, DC39 is engineered to shut itself down for protection if it starts to overheat. This will usually be due to a blockage, and the filter may also need a wash.
You should find the machine will reset itself after it's had at least three hours to cool down. But to prevent any damage to your vacuum, please give the filter a wash, and check for any blockages.
DC39's filter should be washed once every three months in normal use, as shown in the video below. Use cold water without detergent, and allow up to 24 hours for the filter to dry completely before replacing it.
I'm confident this will resolve the issue, but if you'd like any further advice after you've given this a try please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
The belt that turns the rotating brush is loose. Make sure it is on correctly or replace with a (new) tighter belt. This will require you to unscrew a few screws on the bottom & remove the cover. Then remove the roller.
My dyson DC39 makes one noise then another , like air ?
