Toshiba Satellite P105-S6207 Laptop Logo
Posted on Sep 02, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lines on montitor
What part of the laptop do i open up to check if i have a lose connection
Anonymous
Level 2:
Scholar:
  • Expert 53 Answers
  • Posted on Sep 04, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
53
Questions
0
Helped
18473
Points
104
Yes indeed the LCD screen is to be replaced but not everything is lost you might be able to get it serviced and it may be cheaper, just for your reference check this web-site for an idea of prices: http://www.moniserv.com/doc/lcd.html
Peter Young
Level 1:
  • Contributor 60 Answers
Peter Young
Contributor
Level 1:
Answers
60
Questions
Helped
24255
Points
90
Im assuming what you mean is coloured or permenantly black lines either down or across your LCD. If this is the case there are no loose connections that can be put right. The screen will certainly need to be replaced. Ive seen it many times. Sorry to be the purveyor of bad news. The problem comes from the LCD Itself.
1helpful
Vertical line down screen
This problem can be caused by a lose connection between LCD and motherboard, however you can check it by opening the LCD or hinge bezel to ensure if there isn't any lose connection.
Fujitsu lifebook black screen
Sounds like a bad connection. You will have to open the laptop and verify the connections, front and back of the screen. The ribbon cable behind the screen can sometimes lose contact causing that issue. A bump, drop, jar, will cause the connections to come lose a bit. Use a Can of Electronic Contact Cleaner spray to clean the connections and reseat. If you don't feel comfortable opening the Laptop, take it to a Qualified Computer Tech. Have you connected it to a External Monitor to verify the Graphics Adapter is working correctly?
Toshiba laptop with windows vista disconnecting from internet every few minutes. dial up service. no phone or any other devices connected. modem/ wires fine. i have reset settings many times. it is n
If the modem and line in are OK, change cables and clean Phone line jack connections with alcohol. Look for oxidation on pins or bent, damaged pins.
I have constant trouble with my toshiba laptop using windows vista constantly losing the dial up internet connection.
If your telephone line may have disturbances from any electronic devices at any point then this could happen. Try moving other devices especially speakers, mobile phones and TV near the modem. Does your laptop wifi enabled one? Do you use telephone in that line? If so use a line filter with two out. could you give your laptop model no.? There is not enough details to pinpoint the problem
The screen works on one side but is black on the other. separated by a series of bright color lines in the middle. All programs seem to work and computer will boot up. Bad screen or ???
Yeah your screen is faulty prob a problem with the cable might just be lose. I would open it and check the connection. If the connection is ok then either replace the screen which is pretty easy or replace the screen cable which can be awkward.
Hope this helps
I have a Toshiba A200 and the screen is completely
Sounds like the screen is faulty I would check the screen connection to make sure its not lose but I would say the screen is almost gone.
You may need to replace it.
Loses the connection
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
The montitor goes black and/or the system shuts down after only minutes of use. a detailed test of the system did not reveal any problems.
Dear rdg5980,
Try to replace the battery (if it is a Laptop PC) or try to check the hinge or rainbow-cable that connect your Power to Monitor screen, it might be the socket little bit loosen.
GoodLuck!
The light went out on my montitor.Can still see screen no light
You need a new lcd screen & while you're at it replace the inverter. There's no other option. Check ebay for the parts.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
