Food Mixers Logo
Anonymous Posted on Aug 05, 2013
Kenwood kmix the mixer for bread wasn't attached properly but I didn't notice. So it kneaded the dough for 10 minutes. After the kneading, I couldn't get it out, i used a lot of force and then it came out but now it won't fit anymore...what do I do?
Ross Keen
Level 3:
  • Food Mixers Master 1,365 Answers
  • Posted on Nov 07, 2013
Ross Keen
Food Mixers Master
Level 3:
Answers
1365
Questions
0
Helped
582747
Points
2445
Buy a new dough hook
4 Related Answers
Anonymous
  • Posted on Jan 20, 2008
SOURCE: motor is not running now
Yes, bigg t, since you work for Hobart, is there any way to get a refurbished one cheaper? If so, email me [email protected]. THANKS!
Anonymous
  • 135 Answers
  • Posted on Dec 31, 2008
SOURCE: bread dough
Hi. There are several possibilities. First, you should always proof your yeast. Take a 1/3 cup of WARM water, add a half tsp.of sugar and yeast, wait 10 minutes. If your yeast becomes frothy its active and can be used. If not, get some fresh yeast. Second, use a flour that has a high protein content (10-12%) if you're not using pans to make your bread. High protein develops more gluten than low protein flour. Gluten development will give your dough body, and prevent your dough from flattening. Third, after mixing. knead the dough by hand for 8-10 min., cover and let rise until doubled, punch dough down and divide. Knead the portions by hand for 8-10 mins. Shape loaves and place on baking sheet or use pans,let it rise untill doubled,then bake as usual. Been there...Done that. Let me know how you make out. Ricardok45.
Anonymous
  • Posted on Jan 04, 2009
SOURCE: My Kenwood Chef Mixer (Stand
You could contact
http://kenwoodchefrestore.co.uk/2009pro.html
Deborah
Anonymous
  • 145 Answers
  • Posted on Jul 08, 2009
SOURCE: Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
1helpful
What can you use for a hobart h600
The Hobart H600 is a 2 horse power, 60 quart mixer, it can be used for many things in the kitchen. It can be used to make about any kind of food that needs mixed, wiped or kneaded. It works well in a pizzeria for all facets of making pizza from the dough, to shredding the cheese with an attachment, to a restaurant that makes mashed potatoes and fresh bread, to a full service bakery.
However, the biggest thing that you need to know is the capacity of the machine. As overloading the machine can cause damage that may be costly and take a technician to fix. I do not know what attachments you currently have so I will go over a few of them.
The main attachments are a Wire whip, Flat beater, and Dough hook. There are three different types a "D" wire whip (has many wires and is evenly spaced) this is used to whip egg whites, whipping whip cream, etc. The "C Wing" (has six tines in it) is used for items that are heavy for the D wire whip, like whipping potatoes or icing. The last is the "I" whip is similar to the D wire whip just with less tines. The flat beater is used to mashing or mixing examples are mashed potatoes before they are whipped, cake mixes that do not require whipping, batters and icing. The Dough hook is used for kneading dough examples are pizza dough, bread dough, etc.
The biggest thing when using your mixer is to know its capacity for the material that you are mixing. All though this is one of the bigger machines it still has limits. You should refer to this the following link for the capacity of your machine:
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F-7701.pdf
There are also a few attachments that can be put on to the No. 12 attachment hub. A few of these are a vegetable slicer-grater and meat grinder.
I have a kitchenaid 600 professional stand mixer. I was told that you can only use the dough hook with setting 2 for only 5 minutes. What do you do for recipes requiring a longer time for kneading? Is...
You can knead longer than that, but you run the risk of over heating the mixer because at that point the dough is very firm. Your best bet is to knead it by hand.
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
2answers
Bread dough
IT NEEDS TO PROOF LONGER
Beater jams
You are going to DESTROY YOUR MIXER by kneading dough with the flat beater. Read the directions. They spell it out in big letters. Only use the dough hook for dough; only use speed 2.
If the mixer generated enough torque to knead dough with the flat beater (it doesn't), it would tear up and overwork the dough. As it is, you're lucky you didn't strip a gear.
Kneading Blade Stuck on Kenwood Mixer KM300
Lightly tap out the dough with a piece of wood in the direction you would usualy remove it
Top Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Food Mixer Expert? Answer questions, earn points and help others
