Nokia 7610 Logo
Posted on Apr 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In keypad the numbers 4,5 and 6 are not working
I have nokia 7610 suddenly the keys in the 3rd row are inactive
Anonymous
Level 3:
  • Master 470 Answers
  • Posted on Apr 03, 2009
Anonymous
Master
Level 3:
Answers
470
Questions
Helped
166794
Points
1496
There is a cut line between the board, because the 456 a the same line in the outer key, so you need to jumper it , if you dont know let the technician do it, JUMPER
1helpful
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
2answers
Nokia 7610 keys 3,5 and * not working. pls help. thanks....
i think this is a dusting problem so open your cover & clean your keypad if problem not solve then
change your keypad or check their hardware..
Jan 23, 2011 • Nokia 7610
1helpful
The navigation keys of nokia supernova 7610 are not working.. and its memory card has also locked up itself ... plz help.....
open your phone cashing than also 4 screws under LCD.pick key pad,use( - )screw or cutter eyes.clean keypad connector use pencils erraser (it safety).also open white plastic on key pad clean it up too. its often happen.Good luck.
7helpful
I want to reset and flash my nokia 7610
Hey welcome to fixya. Hope u 'll be fine
If u want to format your cell just follow following procedure:-
First of all Switch off your phone then press and hold 3 keys combined
  • Green dial key
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the phone.
  • In the process don't leave the 3 press and hold keys, After some time the phone 'll format completely
Note :all your data will be delete in the process of formatting.
After formatting the cell keep an installed anti virus for your cell.
  • Just open the following link and download this anti virus name as Mccafee Anti virus. Just download it and copy it into your cell. Install it in your Nokia hand set and Enjoy.
  • This is the best anti virus for nokia symbion sets
For download
Just "Click Here"
I hope this solutions will work and helpful 4 u. Best of luck
Please do rate if it is helpful
THANKS
& keep using fixya
Feb 25, 2010 • Nokia 7610
1helpful
MY NOKIA 7610 KEYPAD CONNECTORS TWO PRINT BROKEN WILL YOU SOLVE THIS PROBLEM?
just use jumper between key plate and keypad connector..
Mar 10, 2009 • Nokia 7610
4helpful
7610 keypad not working
check bubble pad then change keypad ic
2helpful
KEYPAD PROBLEMS
Dear Make is software if ur phone key are working on wrong function. if not ok then change the key pad ic (both)even not ok then its prob from CUP check might be possible that when u press the button with speed ur mobile goes on restart then its prob from CPU.
Mar 30, 2007 • Nokia 7610
12helpful
4answers
My Nokia 7610 Keypad Problem
my 7610 keys 2 , 5, 8 and * are not working. kindly give me any solution.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
