Question about Seagate Computers & Internet
I connect my seagate external hardrive to my xbox to store some data on it because my xbox does not have an internal hardrive. So i figured i can use my portable external hardrive to my xbox, and it said i have 32 gigabyte's of free space, when i have 250 gigabyte's. so i looked through the properties of the seagate hardrive and it said that i have 200 gigs of free space left. i need help on why i can only use only a certaini amount of gigs on my hardrive.
Posted by logan bias on
richie46
    Top Expert:
  • Seagate Master
  • 12,962 Answers
Either you have 50 gigs of stuff on there or your hard drive space is not being properly read. U might need to reformat the drive if necessary.
Meanwhile your xbox electronics may have a limit on the size of space - so if the drive has 200 gigs of space on it and your unit will only recognize 32 gigs, then that is all it sees and can use. Capiche?
Posted on Jun 16, 2017
5 Related Answers
Anonymous
  • 23 Answers
SOURCE: Seagate 500 external hardrive
It could be that the PCB or the connection within the external casing has a problem.
Try disassembling it and putting the Hard Disk into another external case to see if the disk is okay, if it is then viola! you have your data back.
Posted on Jan 14, 2008
Anonymous
  • 7 Answers
SOURCE: External hard drive disk space
WD drives file system type is FAT32 by default. FAT32 has a limitation that you cannot transfer a file more than 4gigs. Backup all your data from your WD drive. Format the WD drive to NTFS file system.
Posted on Sep 04, 2008
Anonymous
  • 63 Answers
SOURCE: Problem with seeing files on external Hard drive
What has happened is that your file system on the hard drive became corrupt becasue windows had not updated the MFT on the drive. THe MFT is a table of contents regarding whats on your drive.
What happened is similar to someone cutting out a few pages of the table of contents in a book that has a lot of pages.
Windows tried to fix this stupid programming method by asking people to always use the "safely remove hardware" button in the taskbar to force it to update the MFT.
In this case yur a victim of the Hard Discs MFT not updating properly probably because software was accessing the drive when it was disconnected from the machine.
You need to run chkdsk to have it rebuild your MFT.
http://support.microsoft.com/kb/315265 <-- How to perform Check disk
*NOTE: Remember to use the drive letter that the USB External is on.. Not just type CHKDSK. It will default to drive C to scan for errors. ex: c:\chkdsk g: (where g is the drive your external usb is)
If you get an error like "CHKDSK is not available for RAW drives.. see my notes below.
Beware that it will take a LONG TIME to perform this procedure.
If this doesn't fix it.. contact a data recovery specialist.. It's worth the cost. There are two types. Simple and Advanced.
Simple= recovering files your deleted with the delete button (fairly easy with the right software)
Advanced = recovering files from a hard disk crash or file system corruption. (Not easy and very time consuming)
Posted on Nov 04, 2008
Anonymous
SOURCE: My WD 250 GB ext. HDD, not showing data, but showing free space
files are there but data is not there & its showing file is empty
Posted on Feb 27, 2009
Anonymous
SOURCE: External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Posted on Jun 23, 2009
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
I have an seagate freeagent 500gig external hardrive and it fell off the counter and the part that connects to the cable for transfer data snapped off from the drive. I wiped my laptop and now I can't get...
there is,open the 500gb external case and take out the hard drive. go to your nearest computer shop and pick up an empty external hard drive case for internal drives.make sure its a sata drive,get your hard drive and put it in and reconnect it to your computer. those cases run around 80 bucks to you may need to look online for one to get a better deal
Mar 07, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor 3100 80GB External Hardrive clicking/humming sound.
This could be an issue with the circuit board.I am facing a similar problem & shown it for repairing. And facing issue in sourcing the IC. Seagate is giving support for maxtor after it has taken over. Data recovery is possible only if the circuit is working.
Jan 10, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
Itunes messed up my external hardrive
I doubt that iTunes really moved/reorganized files on your computer.
iTunest may have created its own "Table Of Contents", presenting a "view" of all your files.
Open "My Computer" and open your external hard-drive.
The files should be in "your" order.
Open "My Documents". Open "My Music".
If iTunes really did "reorganize" your files, there's no way to "go back", because "Windows System Restore" does not automatically created time-stamped backups of your 'My Documents' folder (nor of any external disk-drive -- where would it put that much data???).
Jan 02, 2010 | Seagate Free Agent Go Small 12 GB USB...
Light going on hardrive, can hear going but does not do anythng
if the harddrive in side is the same as a normal seagate internal than remove the harddrive out of it`s casing and plug it straight in to you motherboard as a slave unit.
Aug 06, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate 300GB USB 2.0, read write error
Hook it to another computer do see if the drive is the issue.
Oct 04, 2008 | Seagate 300GB USB 2.0/FireWire Hard Drive...
Jan 14, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate external hardrive
Here is the link to the Seagate's utility tools: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Downloads&vgnextoid=51e092db8a13d010VgnVCM100000dd04090aRCRD The links that you are looking for are DiscWizard and SeaTools. And if you have just lost it, here is a recovery program that you can use: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
Mar 20, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Try to plug it into more than 1 computer other than your PC. If it works, then the problem is the interface between the hard drive and your computer and if it really doesn't work, you're solution is have it recover by data recovery experts. Here are a few things you need to keep in mind, on taking your first steps in such a situation: Do not open the hard disk and try to repair it on your own. If you're data is really, very valuable, don't use automatic data recovery tools. Before you bring it, wrap the defective units in anti-static envelope if possible, bubble wrap it, and seal package securely. You also had an option to recover it on your own by using known data recovery software but it's risky compared if you bring it to a data recovery experts. If the problem is within the mechanical parts of a hard drive, there's a possibility that you will not attain a 98% chance of recovery if you do it on your own.
Computers & Internet Logo
41 people viewed this question
Top Seagate Computers & Internet Experts
Michael Thomas
Michael Thomas
ChinthakaJ
ChinthakaJ
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
