Ariel Premium Supply Clearview Pedometer Logo
Anonymous Posted on Aug 05, 2013
Is the Ariel Clearview Pedometer waterproof? - Ariel Premium Supply Clearview Pedometer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
106
Points
21
No it is not unfortunately a lot of pedometers and bands are not.
Do you know if the Fuelband is I have that one and am trying to see if I can swim with it
Skmei # 1058 Pedometer watch - I didn't receive an instruction manual with my watch. I need some instruction to help set the watch...
Hi Keith
The guy in this video finds a paper manual in his package.
You can probably freeze frame it and take a screen snapshot of th manual. Cmd Shift 4 on a Mac places the screenshot photo on the Desktop
Good Luck SKMEI 1058 Waterproof Pedometer Heart Rate Wrist Watch
pedometer how to use YouTube
Mar 14, 2016 • Watches
How do I change the time
Change the time on your pedometer this weekend ...
blog.walkingspree.com > Walkingspree
To change the time on your Omron USB Pedometer press SET and hold it ... AM and PM displayed on your pedometer or it will reset at noon instead of midnight.
[PDF]PEDOMETER - LuckyVitamin
www.luckyvitamin.com/.../Sportline%20Qlip%20Any-Wear%20Pedome...
8. SETTING THE PEDOMETER FUNCTIONS. SETTING TIME. 9. SETTING USER DATA. 10. OPERATING THE PEDOMETER. VIEWING PEDOMETER DATA. 11.
How to Set Up Your Pedometer - YouTube
? 1:51
https://www.youtube.com/watch?v=2Zgh9uDeA4w
How do I reset the time?
How to Configure Your Omron HJ-303 Pedometer
www.walking4fun.com/.../pedometers/...pedometer/how-to-configure.ht...
When your pedometer first comes out of the box, you'll need to configure it. When youchange the battery, you'll have to reset the time on your pedometer, but the ...
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic Institutionyour pedometer and walk your way to better health. Pedometer Setup ... down theRESET button. Additional ... you'll track steps, time, and miles throughout your daily routine. And, in ... Do the math: 20 divided by the number of steps equals.
How to Reset an Omron Walking Style Pedometer ...
www.livestrong.com > Sports and Fitness
Oct 28, 2015 - Your Omron pedometer is a fitness accessory used to provide a great amount of ... session, including steps taken, time walked, distance traveled and calories burned. ... Do not use the end of a pencil to perform a system reset.
When does the clearview pedometer reset
I'm responding 'cuz my Clearview pedometer remains something of a mystery to me, too. So I apologize, right off, about the length and confusion in this procedure. Maybe someone will add a simpler, comprehensive list of commands.
W/o access to a user manual, here is what I've learned about it. Barbara, I didn't think it reset itself... maybe you can explain. I did find that when I hit the "reset" button on the back (to the left of the belt clip), it resets the Step (number taken), Mile (distance traveled), and Kcal (calories burned) to zero. One click for all-three together.
More SETTING steps: The menu is a vertical column to the right of the digital display (from top to bottom: Step, inch, LB, Mile, Kcal). As you scan down the menu, look for the teeny > arrow pointing at one of the functions. Normally the arrow skips from Step, to Mile, to Kcal. If you've been using it, and there are numbers in these fields, you can manually reset these to zero by pressing the "reset" button. Those 3 fields should now register "0" when you scan through the modes as before. I believe this does not reset your stride or weight settings.
These other 2 modes: inch (length of YOUR step), and LB (YOUR weight = this helps in calculating your calorie consumption... I think) were a bit tricky to reset to MY body. I managed to select those modes and enter my own data somewhat haphazardly, by simultaneously pressing the two buttons on the right (Mode, and Set); and then (sometimes, but not necessarily?) pressing the Set button alone. Either way, if you're lucky (!) you'll eventually get a blinking number and the arrow > indicating which field you're in: inch, or LB.
If it is the inch field, it will read 0, or something like 30 (your stride in inches). If you want to change it, press the SET button repeatedly (lower/right) to INCREASE the number in the field. Apparently you can't lower the number directly - if you instinctively press the upper/right button (MODE), it just closes the setting function.
So in order to set to the length of YOUR step, keep pressing (or you can hold it down) until you reach your stride length... it continues up to 120 inches (!!) before restarting at zero. I haven't figured out why it opens in inch, or in LB, but by randomly pressing both rt-hand buttons, I can eventually get into each of the two fields. The weight settings in LB also adjust only upward by pressing the SET button (that is, once you get the field to open). You may have to go to 150# (its max. setting) before you can begin at zero again. Last weird note: When I can't seem to get into these fields at all, I have had some success by pressing and HOLDING the SET button until the reading (usually 0, by then) blinks off and then on, once. Then you can proceed with the other steps.
Aldi Crane pedometer. Where can I get instructions?
[PDF]AU4-PF-6LA - Aldi
https://www.aldi.us/.../1.1.14_Crane_Heart_Rate_Monitor_Watch_...
ALDIFitness watch with speed and distance tracking. Pulse measuring without chest strap. Operating instructions. Item No.: AU4-PF-6LA/6LB. Issue: January 2014.
Woods Hole Oceanographic InstitutionGetting Started: Setting Up Your Pedometer. Starting your walking program is easy! Use these simple instructions to setup your pedometer and walk your way to ...
Tanita PD637 HANDHELD MOTION PEDOMETER Repair ...
www.dqrkc.com/support/p3651266-tanita_pd637...pedometer/page-4
Tanita PD637 HANDHELD MOTION PEDOMETER - Page 4 - Recent ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 308 Snapshot Pedometer Repair Questions ...
www.dqrkc.com/support/p3642406-sportline_308...pedometer/page-8
Sportline 308 Snapshot Pedometer - Page 8 - Recent Questions, ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 310 Qlip AnyWear Pedometer Repair Questions ...
www.dqrkc.com/support/p1496572-sportline...pedometer/page-8
2helpful
2answers
Missing a battery for a Sportline Model 342 Pedometer.
Same problem here. If your pedometer is rectangular, with slanted window, LR 44 battery should work.
How do I take the front of the Bissell clearview off to clean it out?
Hi
Please check these links for step by step instructions on how to clean Bissell Clearview:
Bissell Clearview
Bissell Clearview 2
lease do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
6helpful
Reebok B 2 pedometer
1. Reset pedometer by pressing the reset button.
2. Find a long open place and take 20 steps with the pedometer
closed.
3. Check the number of steps the pedometer counted. It should be
between 19 and 21 steps.
4. If the count was not right, try to move the pedometer forward
(toward your belly button) or back (toward your hip) on your
waist.
5. Repeat this until you get the best count of your steps.
6. Once found, place your pedometer in this spot each day.
3helpful
I am having problems with my Pedometer. What should I do?
Review the following questions for common pedometer troubleshooting: a) Where are you wearing the pedometer? Make sure you are wearing your pedometer correctly by following these steps: * Clip your pedometer to your waistband or belt, directly above your knee. * Be sure your pedometer is perpendicular to the ground, not angled or dangling from your clothing. * Do not wear the pedometer on your shoe, sock, pocket or wrist. It will not provide an accurate reading. * Test the pedometer for accuracy by setting the step counter to zero and walking 50 steps. Check the display. If the reading is between 45-55, your step counter is functioning properly. If it reads more or less, reposition the counter on your waist and check again. * Your pedometer may give inaccurate results if you have had recent surgery or knee, leg, or foot problems. You may be favoring a leg or foot while walking. b)My pedometer has a clicking or loose part sound? Is it broken? No, a clicking or loose part sound is not an indicator of a broken pedometer. Every pedometer has an arm or pendulum inside of it. This is what counts the steps. The clicking noise that can be heard when the pedometer is shaken (or when you are walking) is the pendulum. c)The reset button will not work. The pendulum inside the pedometer is linked to the step counting device. The pendulum may become immobile from time to time, and this can prevent the reset button on the step counter from doing its job. If pressing the reset button a few times does not clear the display, here is what you can do to release the pendulum: * Give the pedometer a few gentle shakes while keeping the reset button held down. This un-sticks the pendulum. * Release the button. If the display has not cleared, press and release the button one more time. * If the display does not reset after trying this once or twice, call Customer Service.
5helpful
2answers
Manual
would like to have an instrustion manual for the evision CLEARview
Top Ariel Premium Supply Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Ariel Premium Supply Exercise and Fitnes Expert? Answer questions, earn points and help others
