Hi Guys,
1. At first the paper got jammed, i took the paper off n pulled off the plug n plug in again.
2. I tried to delete the doc. name that was incomplete printing. It won't allow me to delete, it's still on the printer file list.
3. Now, i can't even print other new doc.files.
Pls advice what shall i do....how do I delete the old hanging file n pls advise how to let my printer HP5510 starts functioning again.
Thanks for your help & support.
Linda
[email protected]
WHAT IS THE OPERATING SYSTEM THT YOU ARE USING
IF THAT IS xp OR vista
GO TO THE PRINTER SPAGE AND RIGHT CLICK ON THE PRINTER AND SELECT RUN AS ADMINISTRATOR
SELECT CANCELL ALL DOCUMENTS AND SEE IF IT CLEARS THE PRINT QUE
STILL IF IT DOES NOT DELETE THE PENDING DOCUMENTS
GO TO SERVICES.MSC WHICH YOU CAN TYPE IN THE START SEARCH OR THE RUN BOX
LOOK FOR THE SERVICE NAMED AS "PRINT SPOOLER "AND MAKE SURE THAT THE SERVICE IS STARTED IF THE SERVICE IS ALREADY STARTED RESTART TEH SERVICE TWICE OIR THRICE
AND THE DOCUMENT WILL GET CANCELLED
BEFORE GOING AHEAD AND PRINTING TRY PRINTING A TEST PAGE FROM THE PRINTER P[ROPERTIES PAGE AND THEN TRY PRINTING OTHER DOCUENTS IT SHOULD PORINT OR ELSE GET BACK TO US AND WE WOULD BE MORE THAN HAPPY TO HELP YOU
THANKS AND REGARDS
HOPE THIS SHOULD WORK
BEST OF LUCK
Hamid
