NetGear WGR614 Wireless Router Logo
Question about NetGear WGR614 Wireless Router
Securing the netgear
We have a neighbour who uses our internet connection through the wireless router. How do we secure the network so the router can be used again?
Posted by luvmylilnic on
  • luvmylilnic Sep 05, 2007
    When we bought the router, (new from a shop on ebay)it didn't come with instructions, so the advice you gave us was a little complecated especially seeing as we are new to the computer world. We will try and follow the instructions as exact as we can. Thankyou vey much for your help and time in this matter. Alison and Anthony
  • luvmylilnic Sep 16, 2007
    I managed to install the NETGEAR but now it asks me for the NETWORK KEY, before we can log on. Is the WEP or WPA? I entered the relevant details but still wont connect me... Myself and my partner are getting really frustrated with this and all because our neighbour uses our connection. She has now found other wireless uses in the area and logs on to their network instead. PLEASE HELP US Alison and Anthony
Anonymous
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username ([email protected]) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 05, 2009
How do i set up secured network?
set-secured-wireless-network-netgear-800x800.jpg Set up a Secured Wireless Network on Netgear Photo is inappropriate for this article Submit
A wireless network is comprised of a wireless router, a computer (or other wireless-enabled devices), a high-speed modem, and a subscription to an Internet Service Provider (ISP). Netgear is a popular manufacturer of wireless networking hardware that allows users to set up a secured wireless network. In order to prevent unauthorized users from logging onto your wireless network to gain access the Internet, and in order to protect the data you transmit and receive online, you should change your wireless router's security settings to create a secured wireless network.
1 Install the router. To install a Netgear wireless router, use an Ethernet cable to connect the router to the cable/DSL modem and use another Ethernet cable to connect the router to your computer. Make sure all of these devices are powered off as you connect them. Once connected, turn on the cable/DSL modem, the router, then the computer, in that order. Allow at least two minutes to pass after turning on each device to give the devices time to recognize one another
2 Log in to the router. Open a web browser and type in the router's address to load the router's settings page. The router's address can be found in the user guide or setup CD that came with your router, or you can download a user guide from Netgear's technical support page (see Resources). Most Netgear routers use one of the following addresses: http://192.168.1.1; http://www.routerlogin.net; or http://www.routerlogin.com. Press "Enter" or click "Go" in your web browser after you have entered the address.
3 Enter the router's username and password. A prompt will appear on the screen when you enter your router's address, requiring you to enter a username and password before you can access the router's settings page. The default username for Netgear routers is "username" and the password is "password." Because the textboxes are case-sensitive, you must enter both of these using all lowercase letters. Press "Enter" to log in to the router and begin changing its security settings.
4 Open the security settings menu. The router's home page has multiple links for changing settings. Find and click the "Security Settings" link to change the router's security settings.
5 Change the SSID, choose an encryption setting and create a password. The default name (or "SSID") of your wireless network will be "NETGEAR." Enter a new, memorable name for your wireless network to help detract would-be hackers from trying to access your router, as most novice computer users with unsecure networks do not know how to change the default network name or institute any other security features. Newer Netgear routers offer WPA or WPA-PSK encryption to secure your network, both of which provide high levels of security. Select either of these. encryption types and create a unique password. This will require all users to enter the password before they can log in to your wireless network. It is important that you create a complex password that has several characters, including numbers. Once you have created a password, click "Confirm Password" to save it. To exit the security settings menu and log off of the router, click "Save" or "Apply" to save the changes you made, then click "Logout" to exit the route
Things You'll Need
* Netgear wireless router
* High-speed Internet service provider (e.g., Comcast, AT&T, Insight)
* Cable/DSL modem
* 2 Ethernet cables
* Computer
* Web browser
* Router address
* Router's username and password
Good Luck : ) ....
How do i reset or changed the password of my router (netgear wireless router MR8v2)?
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
I am a Comcast customer with high speed internet. I am trying to get my wireless router to work on my lap top (Toshiba). The lap top will work if connected to the modem directly. However, when I try to...
How do I secure/lick my broadband service so none of my neighbours can log onto it and it only allows my house hold to use it?
Hi, Inorder to make your wireless network secure you could enable a password for your network which would be required for logging into the network.Please visit the below website to access the screenshots that would be helpful for you to setup a password for your wireless network. http://www.pcwintech.com/screenshots-netgear-wgr614-v7-netgear-firmware Once you are at the website click on each of the screenshots to follow setting up the router for first use.If the router is configured and you would only like to secure your wireless connection then click on the wireless settings where you would find the SSID(name of your wireless network) and below secure options you could select the the type of security after which you need to enter a pass-phrase the box below.You would be able to access the router page form your computer by opening an Internet explorer and type into the address barhttp://192.168.1.1 or
http://192.168.0.1 .
Thank you for your time and best wishes for your effort.
How to use the wireless key
Wireless keys are like your secret password. Provided you have a wireless router and wireless devices to access internet - You might want to secure the wireless signals emitted by the router to ensure that your neighbour is not using free internet :-). So all you do is access the router's setup page and under wireless tab enable the wireless security feature.
Wireles security generally of two types
- WEP
- WPA
select the one suits best to your network and save the changes. once you are done with the router - you will now search for wireless network from your computer/s and select the network. The router will now ask you to type the password (the one you eariler entered on the router). Enter the correct password and you will be connected. Now your neighbours can see your network but cannot access it unless you share your password with them.
How do i secure my wireless network??
Go to the computer that the device is connected to. and use the following link:
http://kb.netgear.com/app/answers/detail/a_id/12873
YoAlternately use Internet Explorer; do this.
http://www.columbia.edu/acis/networks/aptnet/netgear/index.html
How do I switch on WEP encryption to prevent my
please follow steps to fix issue
1.connect WGXB102 to computer with CAT5 cable
open setting page of device
2.open internet explore type there:192.168.0.101
user name "admin" password is "password"
3.under setup click on wireless setting now you can click on WEP then type security
reagrds
prakash
1helpful
2answers
Secure my netgear
First of all understand there are 2 types of security WEP(Wired Equivalent Privacy) and WPA security. WEP is older and easier to hack but is not allowed by some NETGEAR Routers.Wpa is most up to date security. Now back to your solutions follow these steps.
  1. Make sure your computer is connected by Wire to the NETGEAR System.
  2. Open Internet Explorer.
  3. Type www.192.168.0.1 OR www.192.168.1.1 n hit enter.
Now in username type "admin" and in password type "password" (unless not configured)
  1. on the left hand side click "Wireless Settings"
  2. Under " Security Options", select your desired method (preferably WPA2-PSK)
  3. choose Network key it can be anythng from 8-63 characters
  4. n Hit ENTER.
Thats it I hope i helped Take cares.
3helpful
Need to protect my wireless network!
you must logon to the NetGear wireless router and setup wireless security. choose a security type usually WEP, type a key phrase or passphrase and voila, you will have to re-connect on your clients by entering the password when you get prompted for it.
How to enable router security system
Wireless security is difficult to handle simply because the manufacturers have different interfaces to the management software. Netgear has a very good description of how to set up the wireless security in the manual, if you have misplaced the manual it can be downloaded at: ftp://downloads.netgear.com/files/DG834Gv4_RMsrc_13Sep07.pdf
Any posted answer would be multipages long and simply a rehash of the manual.
I recommend using the WPA-PSK.
If you have specific questions they can be answered quickly.
Top NetGear Computers & Internet Experts
Ekse
Mike
Donivan Wise
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
