Lexmark X4650 InkJet Printer Logo
Anonymous Posted on Aug 05, 2013
My lexmark printer not printing full width on page
5 Related Answers
Anonymous
  • Posted on Jan 30, 2008
SOURCE: Lexmark x1185 printing problems
my lexmark will not print in color
Anonymous
  • 60 Answers
  • Posted on Feb 15, 2008
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Anonymous
  • 22 Answers
  • Posted on Oct 16, 2008
SOURCE: Blank page printing-Lexmark x1240
try turning off the printer then reboot the PC, then turn on the printer if this doesn't work try the software may not be installed properly. Try the following:
1 Right-click the My computer icon.
For Windows XP, click Start to access the My computer icon.
2 Click Properties.
3 For Windows 98 or Windows Me, click the Device Manager tab.
For Windows 2000 or Windows XP, select the Hardware tab, and then click
the Device Manager button.
4 Look for the Other Devices category. If there are any Lexmark devices
shown here, highlight them and, then press the Delete key.
Note: The Other Devices category appears only when unknown devices
are present. Do not delete any Lexmark items unless they are
present under the Other Devices category.
5 Insert the CD, and install the software again. Do not restart the computer.
Anonymous
  • 837 Answers
  • Posted on Dec 07, 2008
SOURCE: Lexmark E321 Laser Printer
Check pages 76-80
Sanath Kumar V
  • 684 Answers
  • Posted on Jan 28, 2009
SOURCE: Lexmark 6570 printer won't print the first page
In this case what i would Request u to do is......... Goto Control Panel goto Printers folder......... There u will see the Lexmark Printer Icon........... Just right click on the Printer Icon and click on Properties......... Now click on Advanced and goto Print Processor......... Change it to Lexmark X6500 and NTEMF 1.0008........ Click on Apply click Ok now try to Print.......... Prints Fine............Issue Resolved........
Px650 not printing full page, cutting print area on right
you can maintenance ................. cleaning or deep claening ......click
it is in page set up ................. main........ preferences...
Using MS Access, I am printing labels to a Zebra 110XiIII printer. The output truncates the label to 2" instead of the 3.5" I have the report page settings saved as. I have been through the setup...
First check printer. Change setting "Print Width" to maximum width, save. Switch off. Hold down pause key while switching on (untill all but power light turns off). the subsequent prints should print across the full width. If this is OK fault is with label format.
If you are using windows printer driver check settings there this can over ride printer settings. If using ZPL the problem is most likely in the label format.
I have a Lexmark Z1300 printer. The cartridges are half full or full and the printer sounds like it's printing, but the page is blank.
Make sure you are using the correct cartridges for your printer. Try to remove your cartridges from your printer. Close the cover. Unplug and replug your printer into th power source to reset it. When the printer turns on, reinsert your cartridges. If that doesn't help, try to clean the print cartridge nozzles. Open the Lexmark Solution Center on your computer -> From the Maintenance tab, click Clean to fix horizontal streaks. Click Print. A page will then be printed, forcing ink through the print cartridge nozzles to clean them.
Like to increase the size of letters when I print a document on my lexmark printer all in one
First print to pdf, then from Acrobat print to your Lexmark width increace, decreace, fit to page ... anyway you want
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
How do I increase print size in lexmark 1150 all in one printer
Hi
You can try the scaling function and check the page setup or go to print properties and adjust the slider on your printer to adjust the width before you start printing.
Thanks for contacting fixya.com
Print half of full page
If the printer starts to print and stop in the middle check the eletricity of your place, this may have a variation. If the printer prints a half page and give you the paper, with no jam, check the cartridges and then the main board.
Our lexmark Z705 printer only prints won't print black.
Clean your printer cartridge printer maintainence program or alignment or head clean
Optra S 1625 - not printing an inch on the right side of paper
CHECK THE PAPER WIDTH SETTINGS IN YOUR PRINTER SETTINGS ON YOUR PC OR YOUR PAGE SETTINGS TO SEE IF THERE IS A NON STANDARD PAGE SET UP
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
