How Do You Clean a Wooden Cutting Board?
Wooden cutting boards are visually so much nicer than plastic and glass ones, even though some people think that they are more practical.
Wooden boards can be cleaned, you just have to put more time and effort into it.
1. First wash your boards with soap and hot water and let them drip dry upright.
2. Every few weeks or so, sprinkle coasrse (kosher) salt on the board and then rub it well with lemon that's been cut in half (ie rub the cut side on the wood).
3. Rinse well with hot water.
4. Some people use oils such as walnut or almond oil or beeswax to rub on their butcher's blocks but do'nt use olive oil as it becomes rancid.
5. If you rub oil in wipe off the excess and leave it to dry overnight.
Check to see if the motor is binding up. If you can operate it without the cover, let it run until it binds, then touch the body of the motor carefully. If the motor is hot, it may just need to have the old lube cleaned out and new lightweight oil applied.
This assumes the power supply is functioning normally and all that happens is it just stops cutting, but is otherwise functional with:the computer interface behaving normally
If the interface with the computer locks up as well- it may be a software issue that needs a patch applied. It may also be that motor issue is severly loading down a supply barely large enough for the machine, or it may be loose component on the power supply or the servo board.
If it fails while moving in one direction consistently, look at the servo board, or contact the manufacturer about it as they may have extended a warranty for machines with a known problem..
The
frequency of shredder oil applications is determined by a number of
factors. First of all cross cut shredders must be oiled more often than
strip cut shredders do. A cross cut paper shredder
will require regular applications of shredder oil while a strip cut can
go for a longer period of time without decreased performance. Secondly,
paper shredders that are used more will need more lubrication. A paper shredder
under heavy usage will need oil about once every four hours, while one
under normal use will only require oil once or twice a month. Most
manufacturers recommend oiling the cutters once every 30 minutes of
accumulative shredding, but an easy way to remember is just to oil your paper shredder
every time you change the bag. The type of material as well as amounts
fed at once can also effect performance and lead to the need for oil.
Directions You should only use specifically designed shredder oil to oil your paper shredder.
This oil is designed to lubricate precision heat treated shredder
cylinders, and any other lubricant or oil will void the manufacturers
warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The
first way to oil your shredder is to spray or squirt lubricant into the
opening and onto the cutting heads. The oil is packaged in a squeeze
bottle and is applied directly onto the cutting head in a fine stream.
This is done through the paper entry throat. Take 1-2 seconds to oil
from one side of the opening to the other. Turn the machine in reverse
for about 10-15 seconds to allow the oil to transfer to all parts of the
cutting head. The final step is to shred a few sheets of paper to
remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder
is illustrated in the image above. Simply spread a small amount of
shredder oil onto a piece of paper in a zig-zag type motion. Make sure
that you spread the oil over the entire sheet. (NOTE: you don't need to
soak the paper in oil, just ensure total and even coverage.) Feed this
sheet through the shredder and then operate the machine in the reverse
mode for a few seconds. This will make sure the oil is dispersed
throughout the shredders cutting cylinders. The final step is to shred a
few sheets of paper to remove any excess oil. You may want to repeat
this procedure depending on the results, and is recommended for up to
three applications to be assured of thorough oiling.
You should
oil your cross cut shredder on a regular basis. If you are shredding a
small quantity such as only 50 sheets a week or if you are using a small
shredder, then you should oil your shredder every other day. If you are
shredding a large quantity such as hundreds of sheets, then oil after
30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
If the chain is stretching then it is either poor quaility chain, or there is not enough oil getting to the chain, it is impotant to use a non fling chain oil so as to lubricate the bottom of the bar where most cutting is done. hold the tip of the bar close to a clean peice of card board, rev the saw, there should be a good line of oil showing on the card board.
The frequency of shredder oil applications is determined by a number of
strip cut shredders do. A cross cut paper shredder will require regular
applications of shredder oil while a strip cut can go for a longer
period of time without decreased performance. Secondly, paper
shredder under heavy usage will need oil about once every four hours,
while one under normal use will only require oil once or twice a month.
Most manufacturers recommend oiling the cutters once every 30 minutes of
paper shredder every time you change the bag. The type of material as
well as amounts fed at once can also effect performance and lead to the
need for oil.
to oil your paper shredder. This oil is designed to lubricate precision
heat treated shredder cylinders, and any other lubricant or oil will
void the manufacturers warranty. So don't use WD-40 or the like to oil
The
oil your paper shredder is illustrated in the image above. Simply
spread a small amount of shredder oil onto a piece of paper in a zig-zag
type motion. Make sure that you spread the oil over the entire sheet.
(NOTE: you don't need to soak the paper in oil, just ensure total and
even coverage.) Feed this sheet through the shredder and then operate
the machine in the reverse mode for a few seconds. This will make sure
the oil is dispersed throughout the shredders cutting cylinders. The
final step is to shred a few sheets of paper to remove any excess oil.
You may want to repeat this procedure depending on the results, and is
recommended for up to three applications to be assured of thorough
oiling.
You should oil your cross cut shredder on a regular
basis. If you are shredding a small quantity such as only 50 sheets a
week or if you are using a small shredder, then you should oil your
shredder every other day. If you are shredding a large quantity such as
hundreds of sheets, then oil after 30 minutes of usage or after you
empty the bag.
Most important thing you need to do is to establish the actual oil pressure. put a mechanical gauge on the engine and read real oil pressure. If pressure is low (min is 15psi, I prefer to see at least 20 at idle) there is an internal problem...bearings etc. If pressure is good, sending unit has failed...replace it. I would not drive it 'till the oil pressure is verified as being safe. You might get lucky and someone just forgot to plug in the sending unit, but it must be checked!!! good luck
THE FAN MAY OR MAY NOT HAVE OILING PORTS ON THE MOTOR. IF NOT, THE MOTOR NEEDS REPLACED. IF THERE ARE OILING PORTS ON THE FAN MOTOR, TRY SPRAYING SOME WD-40 IN THEM AND THEN ADDING SOME LIGHT MACHINE OIL TO THE MOTOR. THE OILING PORTS ARE SMALL HOLES AT EACH END OF THE MOTOR WHERE THE MOTOR SHAFT EXITS THE MOTOR HOUSING.
