Hello the error E000 MEANS "fixing assembly faulty start-up (open circuit in the main thermistor)
You need to Check the connector of the fixing film unit or Replace the fixing film unit or Replace the DCNT Borad PCB.
you need to get the service manual for it will help you a lot you can get it from the below link:
http://goo.gl/uYxA40
good luck
SOURCE: mf8180c error code e 197
I believe a E197 error refers to a power problem relating to the fuser. I would remove any covers to access the fuser, remove it and reseat it and any nearby connectors.
SOURCE: System error E000
That's was a miraculous!!!!! My canon Image Class D860 is brand new now after following the steps.
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
This just worked for me on a D860
Thanks
Evenel
Press the "additional Function" key
Press the # key
Press F3 key until "Printer" shows up.
Press "OK" key
Press F3 key until "Printer Reset shows up
Press "OK" key
Press the * (star) key
Turn printer OFF then back ON
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
