Question about Niko OTP-2613W 26 in. LCD Television
I think my NIKO 26 inch LCD TV has the tuner gone bad. TV hangs everytime i turn it on, but when i take it out it works with other VGA input. where can i get a replacement tuner card for this TV?
Posted by vivekiny2k on
  • dennis8597 Apr 08, 2009
    When I turn on my Niko i get either sound but no video, or otherway around. I have to play with the actual on/off switch (not the button). sometimes it works on the first try, but most often i get frustrated and read a book. Anybody have any idea's
Anonymous
I have pretty much the same problem. When I turnm on the set (Niko OPT-2613W) it is hit or miss whether it will work or no. Some times I get audio with no picture, sometimes the other way around. Sometimes I get sound and picture but no controls work (either the ones directly on the TV or the remote). When I turn the TV ON/OFF multiple times (switch next to the power cord) it generally reverts to working correctly until I turn it off when I'm done watching and then the process starts all over.
I consulted a TV repair shop and was advised that since it was an "off" brand they werent sure they could find the repair manual or parts. I don't want to toss it but it really isn't good the way it is. I haven't tried it as a computer monitor yet but I think it would be fine with VGA input. Unfortunately that's not what I bought it for.
Posted on May 03, 2009
  • Anonymous May 12, 2009
    I signed up and asked this question on 5/3 premium live chat and began chatting with an expert on Fixya named Amji at 11:15 pm and the chat just ended and I never did get an answer (as evidenced by my response on my profile "are you still there". I just got my credit card statement and see I was charged the $19.99 on 5/6 for the service which I never did receive. Your web site says "You will not be charged until you accept a solution". During the chat Amji said he was reading my question and then the chat “just ended”. What gives? I never got an answer. I am willing to ask the question again. Every time I try to login and ask the question I’m prompted to pay again.
    Please respond
    This was an original post that I responded to:
    When I turn on my Niko I get either sound but no video, or otherway around. I have to play with the actual on/off switch (not the button). Sometimes it works on the first try, but most often I get frustrated and read a book.
    I stated I had almost the same problem. When I turn on the set (Niko OPT-2613W) it is hit or miss whether it will work or no. Some times I get audio with no picture, sometimes the other way around. Sometimes I get sound and picture but no controls work (either the ones directly on the TV panel or the remote). When I turn the TV ON/OFF multiple times (switch next to the power cord) it generally reverts to working correctly until I turn it off when I'm done watching and then the process starts all over. I consulted a TV repair shop and explained the problem and was advised that since it was an "off" brand they weren't sure they could find the repair manual or parts. I don't want to toss it but it really isn't good the way it is. I haven't tried it as a computer monitor yet but I think it would be fine with VGA input. Unfortunately that's not what I bought it for.
I have a MAG innovision 900p 19" monitor that turns white everytime it is turned on.. I've tried cleaning the dust from the connectors and have tried turning it on and unplugging it. Nothing I can think of...
White screen means that the video signal is not getting from the vga board inside the monitor to the actual lcd screen panel.
It may be a bad vga input board (also called a main board)
OR
It could be simply a bad connection on the wiring harness that connects this board to the lcd panel
Or
it could be a blown fuse on the board on the board that is permanently mounted to the back top of the lcd panel.
I would check the wiring connection to the lcd panel inside the monitor first
Oct 19, 2010 | Mag Innovision LT917S 19 inch Monitor
Insignia IS 26 Inch Lcd TV Problem no signal VGA Input
Most likely this is a resolution issue. Set your computer's output resolution to one that is compatible with the TV, usually 1366x768 for a 720p Insignia TV. More info can be found here.
Mar 05, 2010 | LG 26LG30 26 in. LCD TV
Need screw size for 26" niko tv stand. to mount the tv to the stand
man i looked and couldnt find a size but here is a number to a company who might can tell u, its called peerless mounts 1-800-473-3753 good luck
May 26, 2009 | Niko OTP-2613W 26 in. LCD Television
Where can I get a power cord for niko 26 inch?
95% of all LCD's use the standard PC or Monitor cord. Best Buy ect...
Feb 06, 2009 | Niko OTP-2613W 26 in. LCD Television
NIKO 32 in
I have ordered the owners manual for the Niko OTP3211W.
I'll let you know what happens when it arrives.
Dec 31, 2008 | Niko OTP-3211W 32 in. LCD Television
Acer LCD Monitor AL2671W - screen too bright!
I had the same problem with my TV when I purchased it used. Select the input you are having troubles with and enter "Service Mode" by pressing and holding the "VOL - " button and "CHAN + " buttons on the TV, simultaneously until the screen flashes red one time.
At this point you will be in service mode. Pressing the "MENU" button will open a service menu, which is different from the typical user menu. From the service menu you can further adjust your image settings until you have a decent picture.
Initially my VGA input looked terribly bright and washed out. Now it looks incredible!
Mar 04, 2008 | Acer AL2671W 26 in. LCD Television
Stripes on screen
Same problem here too. Happens everyday now until power is off for a while then picture is stable. Thought it was interference, but I'll look into the overheating issue a bit more closely.
Jan 11, 2008 | Niko OTP-3211W 32 in. LCD Television
Niko Screen and channel problem
Fortunately, I have not had the fuzzy green screen problem in quite awile, and since getting the Dish, I have not had to worry about channel memory loss. I am thinking about turning this one into a computer monitor...is this even possible... and getting a bigger tv for the front room, HD of course.
Nov 23, 2007 | Niko OTP-3211W 32 in. LCD Television
Samsung LN-S2641D 26 Inch Wide LCD HDTV w/ Integrated ATSC Tuner Color Issue
if your tv is on warranty take it back to the agent who you buy it from.if it is out of warranty have a tech look at it for repairs.goodluck.
Apr 03, 2007 | Samsung LN-S2641D 26 in. LCD HDTV
Niko OTP-2613W 26 in. LCD Television Logo
257 people viewed this question
Top Niko Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Andrew Taylor
Andrew Taylor
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
