Question about Panasonic Lumix DMC-FZ10 Digital Camera
Panasonic lumix DMC-FZ10 at least 5 years old no longer focuses
Mid March I took fine pictures one day, then the next I could not get a sharp focus. Have checked everything I could think off, to no avail. Could there be another battery besides the obvious one that needs to be changed?
Posted by arethusa on
Anonymous
    Sergeant:
  • 246 Answers
There is a switch AF/MF to set the unit to auto focus/manual focus, try to set to AF mode.
Here is the link of the manual
http://service.us.panasonic.com/OPERMANPDF/DMCFZ10.PDF
check page 65
Posted on Apr 03, 2009
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-ZS3 When I focus the camera
hi
you have a problem wtih the photo shutter of camera
you must replace it
the cost of it is to high you better replace the camera
Jan 09, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
When half press the shutter button, the camera immedietly snaps a picture, it does not focus on the object or get the correct exposure.
Yeah,why did you half press the shutter?When you take a photo,you should press the shutter with force quickly.I think you didn't set your Panasonic Lumix DMC-FZ5 Camera at a proper mode for the scene,shot with a correct the next time.Wish helpful to you.
Nov 22, 2010 | Panasonic Lumix DMC-FZ5 Digital Camera
My Panasonic Lumix® DMC-ZS3 will not focus properly. All pictures are blurry. Anyone know what might be the problem?
Try checking your settings or menu for a vibration sensor or changing the focus. You might also be using the wrong setting, like indoor, when you're at the beach. You can also change the quality of the pictures and if you are taking still photography or movement.
May 31, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Looking for viewfinder is blurry (Panasonic Lumix DMC FZ28)
There's a small dial on the left side of the viewfinder (next to the flash button) that allows you to focus the viewfinder. I only found it because I had the same problem - must have knocked it out of focus by accident!
Apr 07, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic lumix dmc-fx01 won't focus
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
Mar 29, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Landscape picture
You don't normally want to focus on infinity for landscape shots. Auto focus on mid distance between you and infinity [horizon or most distant object] while half holding down shutter button re compose your pic and shoot. Depth of field will help to ensure that everything is in focus larger F stop more depth of field. f2.8 minimum depth of field. This is digital, film is cheap :-) Using the same focus spot, take one shot at each aperture and decide which aperture gives the desired results in terms of sharpness, I think you will find that will be around f4. Then try different focusing spot [closer or further away] to adjust how much between you and infinity is in focus depending on the results YOU wish to achieve.
Sep 06, 2005 | Panasonic Lumix DMC-FZ2 Digital Camera
Panasonic Lumix DMC-FZ10 Digital Camera Logo
Top Panasonic Cameras Experts
ENFORCER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
