The best solution to these problems is hard resetting your device. A hard reset will bring your PDA to it's factory default state, so your PDA will be as fast as it was when it was brand new. But this process will erase all your stored data (Such as adress book, messaged, appointments, tasks, pictures, ...) so you should consider having a backup of your PDA to your PC with a backup software before you hard reset your device. So later when you hard reset, you can recover the personal data with this backup file and continue using your PDA faster.
To hard reset your PDA, you must press the on/off button and reset button at the same time (reset button is a small button that needs to be pressed with your pen, and usually it is located in the bottom of the PDA). And later, wait a couple of minutes and the windows will be reinstalled and load up with the starting page of the screen alignment. After you completed all the settings, you can recover your data from your backup file (from PC).
what are the software in o2 xda iis?
and how to format the o2 xda iis?
