Hi, your problem seems to be related with the AdaptIQ failing to do an active equalisation. HAve you connected the AdaptIq sense headphones on the AUX (left and right coz it will still fail if only one cable is connected) Also make sure tha the sense headphone cable is in the correct color orientation and none is connected to the black jack just below the red one. Try this procedure and if the system still shows error 10 do the following in sequence...
1. Turn off the media center via the"ALL OFF" button in the tray (no DVD disc inside the tray)
2. Turn off the bass module by the power switch underneath the bass module (certain versions may not apply)
3. Unplug the power adaptor of the media center and remove the power adaptor connection from the wall socket.
4. Unplug the bass module (if this has not yet been done
5. Disconnect all speaker wires (satellite speakers I mean)
6. Disconnet the data cable linking the bass module and the media center
7. Allow 10seconds to pass
After 10seconds then connect the following again in this sequence
1. Connect the media center and the bass module data cable first
2. Connect the satellite speaker cables.
3. Connect the media center adaptor (DO NOT TURN ON YET!)
4. Lastly connect the bass module power cable (DO NOT TURN ON YET!)
Once verything is connected, press power "ON" button o nthe RF remote and the media center should turn on. Only the you should switch the bass module power "ON" so that a fresh handshake is achieved.
This ERROR 10 occurs when either the ADAPTIQ process is interrrupted, the data calbe link between the bass module and the media center is loose or when the power connection is interrupted.
If all still fails, then there is a problem with the DSP board of the bass module and would require servicing.
I do hope I was able to help you
