SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
SOURCE: can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
SOURCE: Volume stuck maxed out
the intrenal switch that controls the volume up is shorted. you need to have it replaced. the short of the switch doesn't allow any other buttons on the set to work because the micro is recieving the volume up command. it's as if there is an invisible finger pushing the volume up button. the switch is a tachtile switch which is very inexpencive to repair about $50.00 total. if you want to do the repair yourself be aware there are voltages that remain in the set that can be harmful. 50% of the time the cause of these switches shorting is improper screen cleaning. some people spray glass cleaner directly on the screen, this is bad. the cleaner drips into the set and lands on the PC board where the buttons are housed. but I've seen the other 50% also which is hummidity, dust(not anyones fault this just happens), and simple switch failure. so becareful repairing it your self
SOURCE: 30HF85 TV with CT-877 remote, which doesn't work.
I had the same problem with my remote...over time it slowly stopped working. (sorry for poor terminology) I noticed that one of the battery terminals was corroded and that the metal connecting the battery to the board was completely gone. I simply swapped this out with one from another remote and now its working fine. Seems the only issue is that the battery was not connected.
I hope this helps.
SOURCE: How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Tell me if there is a battery within this TV set which will require replacement to solve this problem
no there is no battary in tv.
The set works OK otherwise using its own control panel to change channels and its on/off switch to turn it on and off.
your statements itself says that there is no problem in tv.
in my opinion problem is in remote only.
please try
for further help in remote.
hope this will help.
good luck.
