SOURCE: Samsung S800
I have the same problem Having forced the lens out, it retracts when I power off and back to square one. My solution is to force the lens out (was horrible grating sound) and then power off by opening the battery door. The lens stays out when you power on again and it still takes good pictures. Not ideal but better than a new camera.
SOURCE: my samsung digimax s800 stopped
Try to replace the battery with rechargeable ones.
And if that doesnt work, call 1-800-SAMSUNG and have your camera sent for service.
SOURCE: samsung digimax s800 not swiching on
The problem is that the lens is jammed. I had to take my camera apart to unjam mine manually, the cogs that move the lens are not lined up with each other, thats why you hear the motor turning and then you get the 3 beeps because the lens hasnt initialised
SOURCE: my samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
SOURCE: Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
