The rear door latch that releases the rear window so I can open the rear door appears to be a white plastic part that looks ragged and almost shredded. The lock is stiff, but it appears to be the latch, not the lock. Does anyone know the name of this latch? Is it expensive and/or hard to fix?
Drive to a junk yard ask the sales man is it possible that they may have one if not can they go on their phone and ask other junk yard if they have one and if they do how much is it.[ reminder ] the junk yards have 2 prices if you take out the lock your self you pay less if some one from the junk yard takes it out for you
you pay more.
SOURCE: 2003 Honda Pilot Door locks not working
may be a relay switch, or a faulty wire on the right side behind the glove box
SOURCE: 1999 Honda CRV automatic door lock only works for three doors
you have a power wire broke or grounding out some where
SOURCE: 1995 honda accord door won't open.
you'll need to slide something into the window well and try to hit the latch
SOURCE: The back seat latch on my 2005 Honda CRV not not
check to see if parts are jammed in the path of movement
To start, the noun "''rear latch switch'' is incorrect. It's actually called "Slide Door Lock". It's located on page BO-20 of the Toyota Repair Manual for the 2001 Sienna. There are two door locks on one sliding door. One in the front and one in the rear. Obviously, you want the one in the rear. The location for the "Slide Door Lock" (which also contains an electric switch) is in the rear of the sliding door located mid way up door. You can see (sliding door opened from the back) it without dissembling the door. And, the lock is made up of plastic (dirty white in color).
SAME PROBLEM HERE BUDDY REAR DOOR HANDLE VERY HARD, BARELY LOCKS THE DOOR. I DON'T OPEN DOOR VERY OFTEN DUE TO THIS..
