SOURCE: I have medion akoya s5610 laptop. Power light
Before starting a sometimes time consuming
troubleshooting process, make sure you've turned on every
power switch
and power button on your computer:
Note: If you have a multimeter or another electrical testing device
you are welcome to use that to test your wall outlet (and power strip, surge
protector, etc.). The lamp test is useful if you don't have an electrical
testing device.
Replace your power
supply if it fails your testing.
Important: In the huge majority of cases when a computer isn't
receiving power, a nonworking power supply is to blame. I bring this up again to
help stress that this troubleshooting step should not be skipped. The next few
causes to consider aren't very common.
Replace the power button if it fails your testing.
SOURCE: the power on my medion
Could be a number of things. Check in this order:
(before going through the list, have a quick look to see if there is a build up of dust around the vents, if you can hear any hard drive or DVD rom noise and feel air blowing out the back of the laptop.)
Repost if you need further help
Testimonial: "Thank you very much for your help. I did not solve the problem but I now have an idea of what the problem could be. Again Thank you."
SOURCE: my medion akoya laptop won't load past intel screen
This is a hard drive issue or windows have corrupt files, if you have the installation disc try and reload the operational system, if no change! have the hardware checked out at a computer repair store.
