Question about Bissell 6594 PowerForce Bagless Upright Vacuum
How do I use the attachment/brush to clean my couch
Posted by wonder nelson on
  • Bissell Master
  • 18,429 Answers
What will I use the hose attachment for
Hi, it's Jim from Crucial Vacuum!
Your vacuum's hose is a handy tool for vacuuming those hard to reach places. Whether you're looking to detail the interior of a car, vacuum the edges of your floors, or even your couch cushions.
Your vacuums hose has a knack for getting the dust and debris your brush roll may have missed with your initial cleaning.
Most vacuums come with not only a hose, but a variety of attachments, which cover a number of uses.
You can purchase replacement attachment parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=tools&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Feb 25, 2015 | Vacuums
Can I use the Bissell 2x ultra on micrfiber?
Before using your Bissell on a microfiber couch, make sure to check the tags on the couch. Microfiber couches come in different "flavors." There's S, W, S/W and X. Using the wrong cleaning method can damage your couch. Here's an article that goes into more detail on what each code stands for and how to clean each one. Tips on Purchasing and Cleaning Microfiber Couches
Apr 24, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Can I shampoo a couch?
Yes<br /> <h2 class="Heading1a Underline header"><span>Instructions</span></h2> <!-- google_ad_section_start() --> <div class="thingsYouNeed"> <h2 class="Heading5a">Things You'll Need:</h2> <ul> <li> <span>Vacuum and its hose attachments</span> </li> <li> <span>Shampoo specific to the couch's fabric</span> </li> <li> <span>Rug shampooer</span> </li> <li> <span>Steam cleaner, possibly</span> </li> <li> <span>Rag and cotton swabs</span> </li></ul> </div> <ol id="intelliTxt"> <h4 class="Heading4a">Preparing the Sofa</h4> <li id="jsArticleStep1"> Vacuum the sofa, its pillows and its cushions with the hose attachments. Do not forget the arm rests and backing of the couch. This will clean loose dust and dirt.<br /> </li> <li id="jsArticleStep2"> Dust the wood areas with a soft rag and a cotton swab for the area between the material and wood.<br /> </li> <li id="jsArticleStep3"> Find your warranty. If it is still in effect, the warranty may be null and void if you apply any cleaning solutions. Call the company for cleaning instructions.<br /> </li> <li id="jsArticleStep4"> Determine the sofa's fabric. This tag is typically found under the cushion area.<br /> </li> <li id="jsArticleStep5"> Buy shampoo specifically for your sofa's fabric.<br /> </li> <li id="jsArticleStep6"> Rent a rug shampooer.<br /> </li> <h4 class="Heading4a">Cleaning</h4> <li id="jsArticleStep1"> Assemble the shampooer according to its directions.<br /> </li> <li id="jsArticleStep2"> Test a small area of the sofa. The best place may be the back of the couch or under the couch if possible.<br /> </li> <li id="jsArticleStep3"> Clean the entire couch. This will prevent watermarks.<br /> </li> <li id="jsArticleStep4"> Allow it and all its parts to dry before reassembling the cushions and pillows.<br /> </li></ol> <div style="overflow: hidden; color: rgb(0, 0, 0); background-color: transparent; text-align: left; text-decoration: none; border: medium none;"><br /></div><br /> <!-- from fixya rte -->
Jun 12, 2010 | Kirby G6 Bagged Upright Vacuum
How do i use my kirby g6 to clean my couch
You will want to use the hose attachment with the upholstry tool that has about a 4 inch width head on his to attach to the end of the hose. That works best for cleaning a couch.
Dec 11, 2009 | Kirby G6 Bagged Upright Vacuum
How to I attach the stair / couch hose cleaning tool
on the rear of this model there is a suction port that you can open to attach the hose and tools
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 20, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
No suction from upholstery attachment
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I bought a kirby g5 with no manual and can't figure out how to clean the couches with it!!!! help!!!!!
you can turn your Kirby into a handheld by removing the handle (button down on the bottom) if it came with all the attachments. Take the big handle off attach the small one onto it and you can take it and clean your couches, bed, stairs, etc. had mine for twelve years never had a problem with it.
Jun 10, 2009 | Kirby G5 Bagged Upright Vacuum
How do I attach upholstery parts?
Remove the main head and put on the air guard.
Take of the bag assembly and attach the hose.
Mix up the solution in the "Suds o gun".
Attach this to the end of the hose.
When you switch on, foam will dispense from the gun.
Gently sponge this into the furniture.
Please leave feedback
Feb 14, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby Diamond Edition (no power)
You just check the bag "boot" to see if there is something worn down enough to keep the vacuum from turning it back on. If it is worn, buy a new mini-emptor assembly and install it and your vacuum should work fine.
Jan 04, 2009 | Kirby G5 Bagged Upright Vacuum
How do I attach and use the shampooing attachment so I can clean my couch?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=579274
How do I attach and use the shampooing attachment...
Posted by rottylvr on May 08, 2008
I have a Kirby Vacuum and Carpet Cleaner that I know how to use, all except the attachment that I am not sure about. I am not sure if it is a vacuuming attachment or can I attach it and use it to clean my couch, I do not have the user guide for my vacuum as I got it from my son's ex girlfriend in lieu of money she owed me. It looks like it should be used for shampooing things like stairs and furniture, but for the life of me I cannot figure it out! Can you please help me? Tell me how to attach it if it is supposed to be used to clean stairs and furniture or tell me where I can find the user guide to look at and see how to use it......Oh by the way I have a 160 pound rottweiler that tries to live on my furniture and my couch is in desperate need of cleaning, this is my only day off and I have spent all day cleaning carpets due to my dog and would love to clean my couch before returning to work and putting my dog in the back yard now that it is warm enough for him to be outside all day.
Thanks,
Desperate to reclaim her couch
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My suggestion is that you contact the Kirby Co in Cleveland listed below and they will instruct you either to down load a owner’s manual or they will mail one out to you, there might be a local Kirby dealer in your area that might have a manual as well. Also, there is a separate shampoo head that will be in the owner’s manual, you remove the vacuum head and bag assm and attach the shampoo head, make sure you use genuine Kirby shampoo for the carpet. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
47 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
