Try reformatting it by inserting into a card reader connected to PC. If it is indeed only a bad sector in the card then you will lose data but still salvage your card. Otherwise you will lose both card and data. Also, if you are using a linux OS then there are data retrieval methods available from corrupt cards as well. Kindly clarify OS.
This camera needs some internal memory free in order to work at all. It can't use memory in the memory card unless it has some internal memory free. You need to delete some pictures in internal memory.
It should use the memory card memory automatically. If it can't use the card (if card is incompatible) there will be an error message. Some cameras can't use SDHC cards even though they fit in the SD slot. Or the card may need formatting. But first you need to free some memory in the internal memory.
i need to open my SanDisk M2 memory card, but my card reader is unable to read it. please help. there are important files on this memory card. thanks in advance..
To connect the SD memory card to the computer you need a USB memory card reader. Plug the SD memory card into the USB card reader and then plug the card reader into the computer's USB port.
The computer will see this as an external memory card, you can then click on this memory card (it maybe the D or E or F drive) and select the music files from your computer then copy and paste your music files to this memory card. I presume the music files you need to copy are MP3 or MP4 files.
My
Z740 won't format my memory card. When I turn it on - it says memory
card needs formatted. I tell it to format - and it just repeats the
Memory Card requires formatting message.
1. Memory card not formatted. 2. Memory card could be larger than 2GB. 3. Brand of the memory card.
Nokia 6085 uses MicroSD (TransFlash) and it could support up to 2GB. If you're using a memory card that is not formatted or bigger than 2GB, you might get this error "memory card not supported'.
Sometimes, brands does matter. Nokia phones prefer to use Nokia memory cards. So you need to try using different memory card to see if there's a problem with the card or with the card slot on the phone.
in some laptops and desktops the memory card reader is inbuilt, but not in all the cases. for connecting your memory card you need a memory card reader. plug memory card reader to your computer,then plug your memory card to card reader and your memory card will be connected to computer.
