Question about Sony PlayStation 2 (PS2) Console
Ps2 (slim) my ps2 cannot read cd games,the ps2 required ps2 cd or fommating ps2 cd.. what is the problem?and i need to repair by my own..pls give me the answer.. my kids getting bored now. if there is any cd format or software,pls tell me.. and the cd or software can download by internet for free.. :)
Posted by roteiro304 on
Anonymous
  • 37 Answers
Well first off, make sure the disk if in PS1 OR PS2 format. That is what the PS2 Is requesting when it says "Please insert Playstation or Playstation 2 format disk. The Slim PS2 has various problems reading disk.(Don't Know why? I own it and Know it does). The Fat version(1st version) is a much better system, in my opionion. Try blowing air to clean the disk reader. Or changing the disk reader portion out, At a small price.
Posted on Jul 01, 2009
Ps2 slim modded doesn't read ps2 modified games
Most likely the console was modded and it was not modded to take modded games
Jun 23, 2014 | Sony PlayStation 2 (PS2) Console
Slim PS2 can't read some games
please make sure that the disk is readable
please look for the recognized formats in the manual
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 wont SPIN disks it tries to read and spins for like 1sec PS2 SLIM
If it's having issues reading ANY kind of discs (CD's, DVD's, PS2 games) it might be due to a malfuctioning lense or a disk rotator motor issue.
Since it's agaisnt the PS2 TOS to modify or take apart your PS2 you should contact customer support or tech support with this issue.
If there's that option is not aviable you should try ordering the required parts online from different distribuitors: http://www.eachgame.net/category-88-b0-min0-max0-attr-1-sort_order-DESC.html
Mar 05, 2011 | Sony PlayStation 2 Slimline Console
On my ps2 after reading its disc, message will appear "disc read error"
Hello, you are most probably using a PS2 Slim, they have a very sensitive Lens Radiance. If the CD is a little scratched, a CD lens cleaner could help. Or if it is not a PS2 Slim, it must just require a CD lens Cleaner :)
Jan 29, 2010 | Sony PlayStation 2 (PS2) Console
Ps2 slim doesn't play color. i beg you.
I have only seen this when the PS2 slim has been modded. What I do when this happens is hook the PS2 slim to a HD TV. This clears up the color. The modchip seems to drain the video power low enough that the normal TV with composite connection cannot resolve the signal. The only way to repair this is to get a new motherboard that is not modchipped. IF it is not modded, you still need a new motherbaord. Buy a broken will not read discs PS2 slim with that is NTSC or PAL whichever you use. Exchange the motherboards. You also need to be sure the Broken PS2 slim will boot up, and possibly read CD's but not Games.
Jan 16, 2009 | Sony PlayStation 2 (PS2) Console
Can ps2 slim play ps1 cd?
harpy_125..yes they do .but you do need an old version memory card to memorise your games. does it play music cds . if so it should read the games as these are only cd and not dvd..
Feb 09, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 problem
i have had the same problem and i just kept using my disc cleaner and polisher and after a few times it work. if that didn't work get a laser disc cleaner for your ps2
Feb 05, 2008 | Video Game Consoles & Games
Ps2 slim 77004
Problem : Over Heating of your console. try to check the ps2 cooling system. what the FAN/ blower is work?
If not, there is some fuse protection is burn. pls describe your Motherboard types... Hope this be of some help/idea. Pls post back should you need additional information.
^_^ im from Java..
Dec 05, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Read Error
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact [email protected]
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
Read Error (With FFX game)
Hi Raven, Its sounds like you have a PS2 Slim with a melted Laser. What you will find is that the Slim will only read CD's, CDR's, PS1 Games, Blue back PS2 games and DVD's. I can repair this for $35 plus shipping to and from The Playstation Clinic in Fountain Inn, SC. The webpage is www.playstationclinic.com If you do not have a Slim, you either have dirty disc, or Lens. You may have left some fibers from the Q-tip across or around the lens.
Sep 10, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Daniel Dollive
Daniel Dollive
Steven Wander
Steven Wander
Raj Patel
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
